Old 03-08-2012, 07:59 PM   #1
latinofrmnc
latinofrmnc is on a distinguished road
Default Need a MLS head gasket
I'm looking for a mls head gasket any digestions where I can get one ? And if is recommendable to use one.I'm working on my 1987 non turbo supra and I heard that's the best head gasket but don't know where to get one ?????!
latinofrmnc is offline   Reply With Quote
Old 03-08-2012, 08:14 PM   #2
Before you even consider installing a metal head gasket you be absolutely certain the block has been properly prepped or it'll fail in a much more spectacular fashion than the OEM composite HG... and much quicker. The block and head both need to checked for warping and machined for a VERY smooth finish. How smooth it needs to be will depend on which HG you're going with. The Cometic and Titan HGs are the most forgiving of the metal HGs out there and the HKS Stopper HG is the most finicky. Both the Titan and Cometic are easy to find (as well as the HKS line). The first retailer that comes to mind is HorsePowerFreaks.com. They're very reliable.
Re-torque head gasket from 56 ft./lb. to 75 ft./lb. (Good idea or bad idea) Randy0223 MKIII Supra 4 04-23-2011 09:50 PM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
