Old 03-12-2012, 02:32 AM   #1
Wileyk24
Wileyk24 is on a distinguished road
Default Compression Test Results
Hey guys, I just picked up an 87 turbo in December. Had some really nice weather lately so I decided to give her a tune up. I replaced the air filter, spark plugs, spark plug wires, and since I had to pull off so much crap to get to the damn plugs I went ahead and did the valve cover gaskets as well.
While I was in there I figured I would do a compression test too. Here is what I found.
no. 1 cylinder - 180 psi
no. 2 cylinder - 185 psi
no. 3 cylinder - 165 psi
no. 4 cylinder - 165 psi
no. 5 cylinder - 170 psi
no. 6 cylinder - 185 psi
I like how high the readings came back. I performed the test on a cold engine and cranked 7 times for each cylinder. However, I am not sure if I should be concerned with the large difference on cylinders 3 and 4 vs the rest. The guy I bought it from has records that I haven't picked up yet, but he said the HG was done already. Its a super clean car with 91000 miles.
What do you guys think? Thanks in advance.
Wileyk24 is offline   Reply With Quote
Old 03-12-2012, 02:40 AM   #2
A cold test is unreliable. Do it again with the engine warmed up as much as possible while still permitting you to handle it... It's best to do this by running it up to operating temp and letting it cool a bit with the hood open or work with gloves. This allows the components to cool enough to handle on the outside while the internals remain warm.
Weird compression test - is this a BHG?? zyzx2k9 MKIII Supra 2 06-19-2011 02:00 AM
compression test question mastergrader007 MKIII Supra 2 08-09-2008 12:05 AM
WOW did a compression test now i got code 12 n 14 help 88Tsupra MKIII Supra 9 06-30-2007 08:19 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
what are factory compression test numbers? 2JZEFINI-17 MKIII Supra 1 11-05-2006 11:58 PM
