Old 03-16-2012, 11:27 PM   #1
2fast4u
2fast4u is on a distinguished road
Default Mk3 supra leaking oil
Hello iam new here guys but I just did a head gasket change and I start the car an it leaks/drips oil from passenger side of motor I thought It was from the dipstick but it wasn't it. Just wondering what has oil that will make it leak from the passenger side of the motor
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 03-17-2012, 12:33 AM   #2
2fast4u
Default mk3
its leaking from the oil pan gasket and the screws were lose but any ways if i wanted to change the oil pan gasket how would i becuase theres the subframe and this calls for removing of suspension and the subframe is there a way to not remove the subframe please help im only 16
2 fast 4 u
Old 03-17-2012, 02:41 AM   #3
Sonyps307
Drop subframe or lifted motor 4-8". U should replace the oil pump while it's off.
Old 03-17-2012, 02:56 AM   #4
2fast4u
The oil onley leaks when the car is running and I checked the oil pan the bolts were loose so I tightens them but it still leaks only when cars running it onley drips small little drips and drips when the car shuts off right after I turn the car off but drips for like 5 minutes than stops can this still be oil pan gasket
2 fast 4 u
Old 03-17-2012, 03:11 AM   #5
Sonyps307
Is it turbo or non turbo
Old 03-17-2012, 06:19 AM   #6
He/she's got a 7M-GTE.
2slow, do yourself a favor and put all of your specs in your sig. It'll make it easier for others to help you if they don't have to ask for the basic info.
And I really hope you didn't use a gasket on the pan. Toyota specifies that only FIPG is to be used and for good reason. I have no idea why gasket makers insist on including a pan gasket, they're not spec and they ALWAYS leak.
