Old 03-19-2012, 10:45 PM   #1
ebang
ebang is on a distinguished road
Exclamation Blown Motor????? Please help!
Ok I was driving my car home last summer, the temp gage went to max...then back to normal but I lost all oil pressure and when I pressed on the gas just smoke was coming out of the back and no power...the car then shut off I pulled over and it smelled like burning oil plus the oil was leaking under the car...I had it towed home.
I opened up the hood and the #1 plug was off...(popped off??)
I removed the other plugs and they were fried except #6.
The car was turning over but making a wierd whining sound. I am now looking into trying to fix it ..
Is it worh it just trying to replace the wires and plugs of is the engine fried?
Help please!.....
1987 N/A Targa 5 speed
no mods as yet
ebang is offline   Reply With Quote
Old 03-20-2012, 12:40 AM   #2
Do a compression test. Check oil and coolant for cross contamination. If either is leaking a significant volume externally locate the leak. I wouldn't spend a cent on parts until some basic diagnostics are performed.
Please elaborate what you mean in stating the the spark plugs were "fried". Damaged from detonation? Ceramic insulation shattered? How did the #1 spark plug just "pop off"? Is this a 7M, 1G, 1JZ? GE or GTE?
Old 03-20-2012, 02:35 PM   #3
ebang
I will have to try to locate a compression test kit. I never done one how easy is it to do?
When I popped tthe hood the spark plug wire was off and the plug itself was loose, I removed by just picking it up.
I have a 87 N/A 5 Speed.
I do not see any oil in the coolant...none in the resoviour and the oil seems ok...whats left of it.
no mods as yet
Old 03-20-2012, 03:12 PM   #4
Ranma
Ranma's Avatar
There has to be more to the story, what were you doing? Did you introduce anything "special" to the combustion chambers?
Old 03-20-2012, 04:17 PM   #5
ebang
Did nothing different, was just driving home from work like normal.
The olny thing out of the ordinary was a pin hole leak of the coolant from a hose, but I was keeping a close eye and made sure it was topped up every trip to and from work...the drive is 20 minutes and after wards the resoviour was still filled of coolant.
no mods as yet
Old 03-20-2012, 07:03 PM   #6
hbski
hbski is on a distinguished road
just a thought.....i also had a sparkplug boot "pop" off.the reason for my issue was oil in the plug gallery,quite a bit. I was surprised those bolts could leak that much.
hbski is offline   Reply With Quote
Old 03-20-2012, 07:31 PM   #7
Ranma
Ranma's Avatar
Talking nani
Did the hose pop losing all cooling fluid? Where did all of the oil come from? Have you checked the engine for physical damage? Do you see any signs of an explosion? Really did you add any thing to the petrol?
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
1988 supra 7mge engine blown what to do? 88supra7mge MKIII Supra 6 08-23-2010 05:22 PM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Blown line going to EGR Morty MKIII Supra 11 01-13-2008 12:42 PM
Blown Engine routeinet Non-Generation Specific Questions 12 12-30-2005 02:21 AM
