Old 03-20-2012, 09:53 PM   #1
Crop
Crop's Avatar
Default flash code help.. plz
flash flash flash........flash can someone help with this flash pattern? i tried looking for this but didnt see a 3 flash than pause code.
thanks for help.
Old 03-20-2012, 10:26 PM   #2
Crop
Crop's Avatar
looks like its the AFM....can it be cleaned?? if how what do i use? im trying not to spend the 200+ that it costs unless i have no choice..
Old 03-20-2012, 10:54 PM   #3
No, do not try to clean the KVAFM. There are NO single digit error codes. Check it again. Possibly a code 32.
Old 03-20-2012, 11:00 PM   #4
Crop
Crop's Avatar
hey cre, nah didnt clean it and wont if it will damage... the code i got was flash flash flash,,,flash...i seen someone asking a similar question and he had some flash chart that said it was a code 31.. car runnin ok, but when left at idle it will sputter out n stall unless i give it gas....theres NO check engine light on until right b4 stall.. car was inspected today and passed somehow.
thanks for ya time and wisdom cre
crop
Old 03-20-2012, 11:32 PM   #5
The problem could be the BOV. If it's not recirculated you're going to be going quite rich whenever you come off boost. Also, if the spring tension is too low it may be staying open at idle causing an excessive lean condition.
I don't recall ever seeing a code 31 in a MKIII Supra. Odd. Make sure the AFM connector is clean, dry and securely connected. Then reset the ECU and see if the code comes back. There's a list of codes in the FAQ section.
The KVAFM is an optical sensor. 99% of the cleaners people try to use either leave residue or fog the optics.
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
how to do a diagnostic suprra_girl Supra FAQ 40 12-27-2011 08:26 PM
TPS code 41... Cyberguy1992 MKIII Supra 0 04-26-2011 08:14 PM
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
bit sick jake MKIII Supra 1 02-06-2005 12:06 PM
