Old 03-24-2012, 10:51 PM   #1
DawgB0
DawgB0 is on a distinguished road
Post why egr leaking
Why is it leaking when im tryin fire it up? 92 turbo stick...
92' 7mgte MT st8 bakcat
DawgB0 is offline   Reply With Quote
Old 03-24-2012, 11:08 PM   #2
Awyman18
Awyman18 is on a distinguished road
well...theres a gasket...lol so gasket could have gone crappy. Or the 6-8 or 10 bolts could be somehow loose.... Why dont u just take off the egr plate, and block them off...thats wat i did, u dont need it and it will make the temp across 5th & 6th cylinders not be real high.
Awyman18 is offline   Reply With Quote
Old 03-24-2012, 11:13 PM   #3
The system does dick to the temps across 5 and 6 and it's entire purpose is to REDUCE combustion cylinder temps which you'll find are key to better performance, reducing ping and better gas mileage. There's no reason to remove the system beyond laziness and ignorance short of a track dedicated vehicle where swift rebuilds are a must and a common occurrence.
Additionally, it's only active at low-medium loads... There's definitely not a heat issue if there's nothing running through the EGR cooler when the loads are high.
Old 03-24-2012, 11:20 PM   #4
Awyman18
lol i just deemed it not necessary
Old 03-25-2012, 03:01 AM   #5
DawgB0
No wonder never notice the gasket and block it wont affect the smog? I live in california so ya
Old 03-25-2012, 05:47 AM   #6
btwilson86
Super Moderator
btwilson86's Avatar
Yeah, definitely can't delete any smog components living in CA. As stated earlier, check the gasket and bolts. If those all check out, inspect the valve and other parts for cracks. While you're there, make sure your vacuum lines are in good shape and routed properly; they likely wouldn't create the problem you're having, but a properly functioning egr system will help your fuel economy and help you on your next smog test.
In the future, please take a few more seconds when creating your posts to be more descriptive with your questions; the more info we receive, the better we will be able to help you.
Old 03-25-2012, 06:01 AM   #7
DawgB0
Thumbs up
Gotcha i didnt realize lol my bad fasho im new to website thing so yea appearence it foreal
Old 05-11-2012, 12:59 PM   #8
Green7mgte
Supra Forum Moderator
im gonna bring this thread back for a moment.. The egr cooler located on the back of the block. How ez is it to put a new gasket in. Is there anything special to removing it? Is removing, perhaps giving it a nice wipe and installing a new gasket the only things your able to do to this piece? Thanks
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-12-2012, 03:44 PM   #9
could remove it. LOL
Old 05-12-2012, 11:16 PM   #10
907mge
907mge's Avatar
I redid mine with the head off and out of the car. But from what I remember the bolts required a decent bit of force to break loose as well as the gasket had to be scraped off.
Leaking Oil 94TT MKIV Supra 7 10-29-2014 12:41 PM
Cam seals leaking Sonyps307 MKIII Supra 3 02-22-2012 05:21 PM
Leaking oil mauimale5799 MKIII Supra 4 01-18-2011 04:26 AM
leaking engine Ranma MKIII Supra 40 11-09-2010 03:18 PM
Oil Is Leaking I Have Pics!! Need Help!! Ahmad88 Non-Generation Specific Questions 18 07-09-2006 03:56 PM
