Old 03-27-2012, 04:44 AM   #1
phat_toaster
phat_toaster is on a distinguished road
Default Which bushings am I looking for?
I'm really sorry to ask this since it's probably common knowledge out there, but I'm totally new to the wonderful world of Supras, and only somewhat experienced in the mechanical side of things. So, I've seen multiple references to replacing stock bushings with polyurethane ones, but never which bushings in particular should be swapped out. I assume it's the strut bushings? Or is it the control arm bushings? Both? Any bushing I could possibly imagine? And what products have worked well for all you owners out there? Thanks for the help!
'89 Supra Turbo Sport Roof, White on Blue
-3" Magnaflow Exhaust
-HKS Blow Off Valve
-GReddy Turbo Timer
-Tokico Illumina II Struts
phat_toaster is offline   Reply With Quote
Old 03-28-2012, 09:17 PM   #2
Strut bushings??? The only bushings in the struts are part of the damper. The rubber strut "hat" could always stand to be replaced on any car this old. Yes though... replacing the bushings generally refers to ALL of the suspension bushings and the subframe bushings. Inspecting motor mounts for damage is good form as well, especially if the vehicle is from '89 or newer as they use fluid dampened mounts versus the solid rubber mounts used in pre89 MKIII's.
Old 03-28-2012, 11:08 PM   #3
phat_toaster
I found a thread somewhere that somebody had mentioned replacing strut bushings and I thought it sounded a little weird, but I figured it must have something to do with the TEMS or something. But it's good to know that it's one less thing that I need to replace!
-HKS Blow Off Valve
-GReddy Turbo Timer
Has anyone replaced and installed there own bushings? cvbikeguy MKIII Supra 0 04-26-2010 07:06 PM
Automatic shift lever bushings mrnickleye MKIII Supra 0 10-15-2008 05:24 PM
ma70 polyurethane subframe bushings ronniek MKIII Supra 0 03-22-2007 07:04 AM
Rear Suspension Bushings, 89 MKIII mrnickleye MKIII Supra 4 02-07-2007 06:15 AM
Lubing poly bushings? Burn N' Up MKIII Supra 4 11-10-2005 05:48 PM
