Old 03-30-2012, 06:01 AM   #11
DawgB0
DawgB0 is on a distinguished road
check it out and tell me what you see missing, think need to be repaired.. i has done timing belt to TDC due to the cam was off by 1 or 2 tooth and cam wasnt even at TDC so its done about to put the cover back on. WTF wit ignition system idk wat da hell in their mind thinkin its fixable lik dat and that inculde starting system too, i just dont get it so thats y i uploaded pixs so you undy what im goin through, THANKS in ADV!!
92' 7mgte MT st8 bakcat
DawgB0 is offline   Reply With Quote
Old 03-30-2012, 03:14 PM   #12
DawgB0
finna goin CRAZY!! haha any1 pls help me out by look at my rigged supra in my album.
Old 03-30-2012, 06:25 PM   #13
btwilson86
Super Moderator
btwilson86's Avatar
Thanks for posting the pics, but there's very little that can be done to help diagnose from looking at pictures.
Let's take a step back and establish what's been done so far. I believe you said earlier that you have fuel; what steps did you take to verify that the engine is getting fuel?
Have you checked to make sure there are no obstructions anywhere in the intake that would hinder the engine from getting enough air?
Are all of the sensors plugged in?
In the fuse box, is the 15 amp EFI fuse making a good contact?
Have you messed with the ECU, and if so is it properly mounted and plugged in?
Old 03-31-2012, 03:03 PM   #14
DawgB0
I jumped b+ n fp my friend hear the pump, i smells the gas when i cranks it few time so yea
Now i suspect i miswired the ignition coil so give me pix or which wires im suppose to connecting, due no sparks now.
I has replaced new fuses unnessecery but yea why not.
I has reconnected the vacuum correctly way.
Did check all sensor.
Got me new battery.
New 3 gallons of gas.
Starter system im leave it alone since it will crank everytime so focus at ignition coil wires here.. i mite misconnectes one of dem tjen sld able to get spark after i found a pix or sum1 tell me wat color the wires suppose be connecting thanks. Then it sld be my final question.
Old 04-01-2012, 03:28 AM   #15
btwilson86
Super Moderator
btwilson86's Avatar
I have a friend with a 7MGTE waiting to swap into his Supra, I'll see if I can get out to his place sometime soon and check out the coil pack wiring for you. When you mounted the coil packs, did you attach the grounds coming off of them too?
Old 04-02-2012, 04:05 AM   #16
DawgB0
Of course i made sure everything is well connected and earthed and yea they all are, i already tested all voltages n keep getting 12v means its connecting but no spark or i reLly does but wrong wire!! that y i need help by give me closer pix of the wires or just tell me off of any turbo mk3 jus lik my pix above
Old 04-02-2012, 04:21 AM   #17
btwilson86
Super Moderator
btwilson86's Avatar
Ok, here are the pics I could get. Coil pack connector,individual coil connector, and the coil pack ground. I just realized that the first pic is probably useless since I don't have one of the wiring harness side, so hopefully someone else can post a pic of that one
ID:	4529   Click image for larger version
ID:	4530   Click image for larger version
Old 04-02-2012, 06:34 AM   #18
DawgB0
Look lik not turbo to me i dont see 3 connectors to 3 coils if it was it then almost, what color goes to another? Lik
green to ...
Black to ...
White to ...
3 tans to ...
That kind answers im looking for thank in Adv!
Old 04-02-2012, 08:40 AM   #19
DawgB0
I keep gettin flashs non stop means no codes.. just stupid wires, Any1 wit gte?
Old 04-02-2012, 09:26 AM   #20
interested!
Question stumpted!
Hi! this is a picture of my coil pack earthed ( grounded ) out , is yours the same? -very important - no sparks without .My car is a '89 7mgte. MA70. Also-check that all of the earth ( ground ) wires are connected UNDERNEATH the inlet manifold , you'll need a good mirror to see them -theres loads of them .
Really Bad weird starting problem? Raysupra MKIII Supra 7 12-04-2010 10:45 PM
'86 2.8L starting problem daveydogtx MKII Supra 1 11-20-2010 04:34 PM
help asap starting problem JaegerUtah MKIII Supra 6 12-31-2009 06:47 AM
mysterious starting problem stevanom MKIII Supra 7 11-14-2006 08:50 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
