Old 04-02-2012, 11:31 AM   #21
interested!
Question stumped
Originally Posted by btwilson86 View Post
Ok, here are the pics I could get. Coil pack connector,individual coil connector, and the coil pack ground. I just realized that the first pic is probably useless since I don't have one of the wiring harness side, so hopefully someone else can post a pic of that one
Hi! -Had a close look at your ground wire , seems a bit loose, so could you be suffering bad starting? . Also, the ground from the plate should be connected to the cylinder head as the cam cover is mostly insulated ( sits on a rubber gasket and held down with rubber washered bolts ) .
May I suggest that a bulb and wire or a multi-meter be used to confirm continuity of the wire and the curcuit or plate is fully earthed .
Old 04-02-2012, 01:11 PM   #22
btwilson86
Super Moderator
btwilson86's Avatar
Interested- the upper intake is currently removed on that engine as we are in the process of swapping a usdm wiring harness on it, so that's why nothing is really connected atm.
Dawg- its from a turbo, why would i take the time out of my day to send you pics of a N/A? Like I said above, I don't have a pic of the harness side of that connector so I can't tell you what wires connect to what. There are hundreds of people on here who actually own 7mgte Supra's (the one i took the pics from isnt mine), one of them will have to help you.
Old 04-02-2012, 01:53 PM   #23
interested!
Wink stumped
Hi! -thanks for your feedback , just trying to assist , my car wouldn't start after overhauling following a BHG , so I know how frustrating a non-starter is , got it going eventually after finding my ground wires were not re-connected underneath the intake manifold and , the grounding wire was very corroded and only connected by 3 strands at the coil plate , thats why I made a new one .
Old 04-02-2012, 04:51 PM   #24
DawgB0
DawgB0 is on a distinguished road
Yea your right i didnt noticed it until later last night but already so late i had to grab sleeps lol was lazy edit mine ,but you are right its turbo now i got it correctly..
Blue/redto black
Blue/yellow to white
Yellow to green
3 tan wires to black n orange
jus made me 2 ground wires jus in case lol
92' 7mgte MT st8 bakcat
DawgB0 is offline   Reply With Quote
Old 04-03-2012, 07:08 AM   #25
DawgB0
Yep it must be correct but wtf same result i might.have a professional do it for.me as i give up on it. Wtf with no spark? i have gas, air, no spark..
Old 04-03-2012, 06:57 PM   #26
DawgB0
Huh wtf now it jus crank few time then die even have battery jumpstart.. i had instal new wires for cam sensor n followed it correctly 1-2-3-4 to blue, red, black, yellow. Then huh y i dont even see engine lighy on its still off but just crank ok?
Old 04-10-2012, 10:22 PM   #27
DawgB0
i had a experienced mechanic check it out within 20 mins he told me the ecu need to be replaced i looked at it, smelt small burn, n i cleaned it then try again then engine just cranks. Starter too it needed to be replaced i has tested it its great no voltage drop. i hope its not ECU cuz its already so hard to find a +89 turbo m/t ecu in bayarea foreal. wld be nice if have any1 who have supra n a mechanic too that live near me come through and help me out would be awesome, thanks.
Old 05-04-2012, 06:08 AM   #28
DawgB0
Nothing so far only cranks, i have all 4 wires grounded to intake mod. Have set tine to 0 and cps keep bein out of tooth maybe its broke? How am i suppose to know of im exactly TDC anf i already changed oil wow 1 years parkin turned out got 2 gallons ouy smellin lik gas! I have home battery charger so i know battery alwayz full 13.4. Already took starter out and have 2 starters n ECU workin perfect.. huh wat hell? Im so pissed i dunt get to drive it so far smh i have so much faith.
Old 05-04-2012, 10:36 PM   #29
DawgB0
lmk if im off base or right base?? tks.
Old 05-05-2012, 01:40 AM   #30
btwilson86
Super Moderator
btwilson86's Avatar
This should help with the timing:
http://www.toyota-supra.info/forums/...-e-timing.html
Let us know what happens after you are 100% sure it's set properly, then we can progress forward with things to check
Really Bad weird starting problem? Raysupra MKIII Supra 7 12-04-2010 10:45 PM
'86 2.8L starting problem daveydogtx MKII Supra 1 11-20-2010 04:34 PM
help asap starting problem JaegerUtah MKIII Supra 6 12-31-2009 06:47 AM
mysterious starting problem stevanom MKIII Supra 7 11-14-2006 08:50 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
