#1 |
Hello!
Iv got this problem, it doesn't feel good driving with it. So after a minute or so after starting the engine cold, the oil lamp shows up and stays on untill i kill the engine. However the oil pressure is good, if i can trust the original pressure gauge? Shouldn't those two work together or is it two separate systems? And there is one thing too! Im not 100% sure that i got the right oil stick, i fear its to short, cuz there is on that is shorter right? Im sure i filled the right amount of oil at last change and it just showed up on the bottom of the stick ![]() / SweSupra |
#2 |
Maybe someone with at -91-92 supra can go out an measure the oil stick for me?
/SweSupra |
#3 |
![]() Toyota Racing Development Join Date: Apr 2007
You need to specify which engine you have. The measurements for 7M-GE, 7M-GTE, 1G-GTE and 1JZ-GTE are all going to differ, I'm sure. If it is a 7M, those measurements have been posted and you should be able to find them is you search the forum a little. If it's a 1JZ or 1G there are very few owners of such vehicles here... If you can find out who they are you may want to try sending them a PM directly.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
Thread Tools | |
Display Modes | |
Power Steering Pressure Hose Step by Step | SilverMK3 | MKIII FAQ | 1 | 02-20-2011 09:38 PM |
7MGE oil pressure problems | I h8 Hondas | MKIII Supra | 18 | 07-18-2010 06:27 PM |
Oil Pressure? | supraguy | MKIII Supra | 3 | 09-16-2009 08:35 PM |
7MGE oil pressure | Arne (Denmark) | MKIII Supra | 14 | 07-31-2009 10:07 PM |
Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
