Igniter problem!? needs REAL QUICK help..
:rolleyes2 i dont get it why it only crank 2 revs den only starter and transmission is spinning with nothing going on with engine thats only thing i keep getting until i unplug the igniter then it CRANKS!? then died again:frown:
the day before i HAD it running but FREAKIN STUPID movement, turned it off :eek3: then tried again after i brought me spark plug for #1 n #6 but alarm went off when i unlock it :squint: but i had it disabled, about that what exactly wire am i suppose to connect to make it think the hood is alwayz open. i needs a wiring for ignition system?? because i suspect mine is took out and connect direct to the battery i forgot a pix i will show u in mornin as it gets bright again.. THANKS |
