Old 03-30-2012, 02:21 PM   #1
Joefishizzle
Joefishizzle is on a distinguished road
Default 7M pan bolt
Hey does anyone by chance know the thread pitch of 7MGE oil drain bolt?
Also did the bolt have a washer, plastic washer, or anything on it? Mines tight as hell but won't seal..
Joefishizzle is offline   Reply With Quote
Old 03-30-2012, 03:07 PM   #2
DawgB0
DawgB0 is on a distinguished road
Didn't u research why? Its most common problem. If you are in cold situation then maybe its because the gasket is cold makes it leaking somewhere you couldn't see then when it got warm it went away? Then yup you will need new gasket so this problem can go away and use correctly torque then should be no problem. gud luck
92' 7mgte MT st8 bakcat
DawgB0 is offline   Reply With Quote
Old 03-30-2012, 04:40 PM   #3
I don't have the sizes handy right now. The drain plug uses a plastic washer (a fiber washer is an acceptable replacement). It is possible to damage the pan in a rather unexpected way from over tightening. With the drain plug out the surface which sits under the flange should be flat. When over tightened a dimple will appear at the 6 o'clock position which creates a constant, slow leak. Short of pulling the pan to fix the crushed weep using a healthy amount of teflon tape is a reliable solution.
Old 03-30-2012, 06:31 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
I also don't know the size off hand, but you can call the Toyota dealership or your favorite auto parts store and they should be able to tell you the thread diameter and pitch. A search on Google would also likely yield the results you're looking for.
Old 03-30-2012, 08:13 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
I think there are 2 different sizes used, UK are M12 x 1.25 not listed below but may help for future ref
Old 03-30-2012, 10:31 PM   #6
Joefishizzle
Thanks everyone,
Its a M18 x 1.50
I took it off, fucking annoying, previous owner didn't have a washer or anything on it.
Smh.......
A Little Story about a crank bolt abhattan MKIII Supra 17 03-28-2013 01:06 AM
Targa Top bolt is striped out gtmustangman MKIII Supra 7 02-08-2009 02:41 PM
stripped rear end bolt 87 Supra MKIII Supra 5 10-16-2007 02:40 PM
Bolt Snapped - Sealant? go.stfu Non-Generation Specific Questions 3 07-25-2007 03:28 PM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
