Old 03-31-2012, 09:18 PM   #1
iphearbunnies
iphearbunnies is on a distinguished road
Default i need HELP please?
i have a stock 1988 turbo supra and it idles at around 550 rpms and it seems to lower then higher at random times. i would like to know if i could adjust the rpms or not? any help would be needed.
iphearbunnies is offline   Reply With Quote
Old 04-01-2012, 02:24 AM   #2
The idle is computer controlled and not to be manually adjusted. If the idle is wandering like that there are a few possibilities. I suggest you begin with checking for diagnostic error codes (covered in the FAQ section) and inspect for leaks in the intake plumbing, PCV and vacuum system.
