Old 04-01-2012, 05:16 PM   #1
brianrfrc
brianrfrc is on a distinguished road
Default supra 2.0 twin turbo non starter
My mate has just got his hands on a wide body black GA70 with a sunroof
It won't start up at all fuel pump runs on engine cranking and using diag block it just keeps cranking and cranking
There is 1 fault code and its 34 checked all that area and all is sound
plugs getting fuel and sparking the car will start with brake cleaner up the intake but cuts out one dry any help would be very greatfull
brianrfrc is offline   Reply With Quote
Old 04-02-2012, 01:48 AM   #2
If the code 34 is persistent you've got a wiring problem or the sensor or ECU has a physical defect. If it were just a boost leak you wouldn't see it until the engine had been run.
Have you made sure you've got spark when cranking?
Check for a signal on the STA input at the ECU while cranking.
I can't offer much in the way of specific information, the 1G never made it to the 'States' in any form and I don't know of any online resources for the 1G. This forum is largely US-centric (not by design), there is a UK specific Supra forum (mkiiisupra.net) where I'm sure you'll find more 1G-GTE owners and resources.
Information about non turbo Supra Jimbo_2JZ Non-Generation Specific Questions 3 02-20-2009 10:13 PM
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
MPG on a twin turbo supra Legionnaire MKIII Supra 0 03-03-2006 08:02 PM
Supra Twin Turbo 97 - 01: Coming to UK! DShox Non-Generation Specific Questions 1 04-02-2005 02:04 PM
