Old 05-29-2012, 05:47 PM   #11
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Okay, so I have an auto harness I want to put in my manual supra.
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
Old 05-29-2012, 07:21 PM   #12
btwilson86
Super Moderator
btwilson86's Avatar
You will need to place a jumper between 2 connectors to bypass the neutral start switch (that isn't present). And if you want your reverse lights to work, you have to create a jumper for them as well. Other than that, the harness is plug and play
Old 06-11-2012, 09:09 PM   #13
supraheelfan
To clarify on your statement btwilson86, if this is not done (jumping the 2 connectors to bypass the neutral switch), will it hinder the car from starting at all? We put an 88 auto turbo harness in my 87 manual and its not wanting to crank at all.
Old 06-11-2012, 09:42 PM   #14
btwilson86
Super Moderator
btwilson86's Avatar
Correct. This will cut power to the starter solenoid, so the starter motor won't crank.
I believe I may have mistyped my previous post, there should be a round connector with 3 terminals heading down towards the transmission; the jumper connects 2 of those terminals to complete the circuit. The reverse light switch connects to 2 different connectors. I'll see if I can find the connector and pins in the tewd for you
Old 06-11-2012, 09:45 PM   #15
btwilson86
Super Moderator
btwilson86's Avatar
To complete the starting circuit, you will need to place the jumper between terminals 2 and 3 in connector D at the top of the image
Old 06-11-2012, 09:53 PM   #16
btwilson86
Super Moderator
btwilson86's Avatar
For the reverse lights, you will use connectors A, B, and C (B is the same connector as above). You should have A and B on the new wiring harness, connector C is on your transmission. You will want to run 2 wires, one from connector A pin 5 to connector C pin 1, and the other wire from connector B pin 1 to connector C pin 2. It actually doesn't matter which wire goes to which pin on the transmission connector (C) as its just a open/close switch.
Hopefully all that makes sense lol
Old 06-11-2012, 10:26 PM   #17
supraheelfan
Thank you! This info goes a long way, and of course, you might not see the end result of your effort, just keep in mind I'm doing an extra dounut and burnout just for you. Keep up the good work guys.
in need of a 7mgte wiring harness 2genfun Parts Wanted 0 09-21-2011 12:12 AM
need 7mgte wiring harness marcmann982 Parts Wanted 0 09-13-2011 12:51 AM
engine wiring harness 7mgte mysonscars MKIII Supra 1 07-18-2010 06:02 AM
7mgte wiring harness Rob1 MKIII Supra 5 06-07-2010 04:19 AM
question about wiring harness????? tone loc MKIII Supra 2 08-30-2006 09:20 PM
