Old 05-25-2012, 09:48 AM   #1
S-mk3-B
S-mk3-B's Avatar
S-mk3-B is on a distinguished road
Default Need tips on Swap!?
Wsup guys, so I'm going to be swapping my supra's 7mgte with another 7mgte in a week or so. So I just wanted a heads up if there would be anything I should look out for. For example, would there be anything I would need to transfer from my old engine to the new one? Or would I have to get any additional things components? I'm new to this so I just want to make sure that I get it done right,
Any suggestions and comments are welcome and appreciated, so thanks in advance!
S-mk3-B is offline   Reply With Quote
Old 05-25-2012, 12:48 PM   #2
Green7mgte
Supra Forum Moderator
electronics!
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-25-2012, 01:12 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
And all your emmisions components. Are you getting a JDM engine?
Old 05-25-2012, 03:15 PM   #4
Green7mgte
if he is getting a jdm. could you swap over the us egr? does the jdm have the cooler in the back and the ports for the pipe? or would you just swap over your usdm intake plenum?
Supra FAQ
Supra MKIII FAQ
Old 05-25-2012, 06:41 PM   #5
S-mk3-B
S-mk3-B's Avatar
Oh yeah sorry i didn`t include that, but yeah its a JDM engine. And i do remember somewhere saying that you will need to transfer over the Crank Sensor/EGR/CAS.
Old 05-26-2012, 01:50 AM   #6
btwilson86
Super Moderator
btwilson86's Avatar
JDM engines have all the ports for EGR, you just have to remove the block off plates and swap your parts over (including the cooler). The easiest way I can think of to make sure you do everything right is to pull the engine, put the 2 engines side by side, and swap over everything that's different. Depending on year, you may have to swap oil pans and oil pump pickup tube/screen. Since you have a Cali car, you will have more emissions components and electronics. Be sure you get them all so you can pass that wonderful smog test
Old 05-26-2012, 01:54 AM   #7
S-mk3-B
S-mk3-B's Avatar
Alright sounds good, thanks for all of the help and suggestions! If there is anything else then just lemme know. And ill definitely post back up if i run into anything else
Old 05-29-2012, 11:09 PM   #8
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
since your going to take the engine out it would be best to give the engine bay a good cleaning to get the dust and grime out.
Also, its probably best to change (or at least check) the alternator and starter on the new engine. More than likely it is or it will fail given its age.
too lazy to find a funny quote, buuuutttt off the top of my head. "life always= how well you treat your car, put crap in ur car, then car breaks down, then miss important meeting, or work which just so happen u cant miss another day or ur fired... and end up with a crappy life.
driving an '88 supra
gloreboy89 is offline   Reply With Quote
Old 05-30-2012, 12:02 AM   #9
Drake69
Drake69's Avatar
Drake69 is on a distinguished road
Gaskets.
Gaskets, gaskets, gaskets, gaskets. Should do them all while the engine is out of the car. Front and rear main seals, all new belts including timing belt and pulley, basically freshen up everything you can while you have the chance. Plan on replacing worn out rubber hoses as well, since many of them will probably be as old as the engine itself and have never been pulled off. Driftmotion has an entire 7M kit of gaskets and seals for just such a job, and there is also a silicon hose kit you can get to replace all the rubber underneath the hood as well. You have to measure and cut the right thickness hose for each one, but it saves future headaches and makes the engine bay look even better. Don't forget to toss out those old hose clamps and get some new ones that screw on tight with a flathead screwdriver.
Also, like it's been said before, starter, water pump, oil pump (if you can afford it), etc...
Drake69 is offline   Reply With Quote
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
Supra mk? swap 1jgte twin turbo yanbeliveau MKIII Supra 1 11-16-2011 10:57 PM
MKIII 1JZGTE Swap How To! Pic Heavy Travis89Turbo MKIII FAQ 12 03-16-2011 05:22 PM
all their is to know for a 7mgte swap mkiii<3 MKIII Supra 0 10-03-2010 10:23 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
