#1 |
So this randomly just happened today... I park my car and the brake lights are still on. I checked to make sure the switch was turned off for all the lights and it was. Anyone have any idea what could be the problem?? or what I should check for?
I'm most likely just gonna disconnect the battery and put it back on to see if its doing the same thing. Any and all help is greatly appreciated!! |
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
Test the switch under the dash and make sure the rubber bumper which the plunger contacts is still in place.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
http://www.turboninjas.com/mk3supra/...ndiv/22_BE.pdf page BE-17. "Stop lights stay on" has a singular trouble shoot of "adjust or replace switch". Also.. if you park it on a FLAT surface, put it in park (or in gear if it's a manual) while turned off, and with the parking break down, is the light still on?
#4 |
Rubber bumper? is that suppose to be on the brake pedal? or the pin that gets pressed in by the brake pedal?
#5 |
I can't even remember for sure if there was one in that location, check the EPC. There was one for the brake or one of the two clutch switches which had a bumped on the strike pad. If the bumper broke off it left a hole so the plunger be depressed.... It would just go through the hole. It's not unique to the Supra.
#6 |
I had a similar thing happen 2 years ago. Found the remnants of the rubber bumper when I dropped the under-dash panel. I wound up JB-Welding a penny to the brake light switch tab to cover the hole. Cost me probably $0.03 for a fix. Just remember that JB-Weld likes a rough sanded surface to bond to.
#7 |
Plenty of hardware stores sell rubber bumpers with the push through mounting nipple.... just like what was already in there. They cost maybe $.50 Now if you already have JB Weld $.01 is definitely the cheaper option.
#8 |
i got one from toyota for 1.00 apperantly other modern modles still use the same little bumper so thats always good to know
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come |
Thread Tools | |
Display Modes | |
My brake lights are stuck on. wtf! | Isphius | MKIII Supra | 16 | 09-07-2009 08:48 PM |
Brake Lights | zebrahabitz | MKIII Supra | 2 | 08-13-2009 06:29 AM |
Brake lights not working! | lifesnotfair | MKIII Supra | 18 | 05-05-2008 11:40 PM |
Instument Cluster and Back lights don't turn on! | Paulv95123 | MKIII Supra | 9 | 06-12-2006 11:21 AM |
87 supra brake lights | ministrytrav | MKIII Supra | 4 | 11-23-2005 08:53 PM |
