Old 04-11-2012, 02:53 AM   #1
2genfun
2genfun is on a distinguished road
Default efi fuse keeps popping?
so my 88 turbo has been running very well and all i have done today was swap some 550cc and new clips in...now anytime i hit over 50% throttle the efi fuse keeps blowing up on me. i can swap a new one in and drive normal. In neutral it'll rev with some misfire but if ur driving and put a big load on the engine = popped fuse...
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 04-11-2012, 03:20 AM   #2
Well, then grab a meter and start testing for the short.... Start with testing the injectors.
Old 04-11-2012, 03:32 PM   #3
pandrade
pandrade is on a distinguished road
i dont want to be the odd ball question but your tag says 7mgte, wouldent you do more harm than good whith 550cc injectors if not combined whith the additonal hardware requierd to run them properly ( more fuel needs more air)
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Engine knock 3k RPM Supra Saiyan MKIII Supra 35 02-25-2011 07:40 AM
foglight anyone kelloggs067 MKIII Supra 1 10-06-2009 02:08 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Wiper fuse short? kewlcoconut MKIII Supra 10 02-27-2007 04:43 AM
Missing Fuse?? kewlcoconut MKIII Supra 7 10-17-2005 02:29 PM
