Old 10-06-2005, 10:35 AM   #1
smurfmods
smurfmods is on a distinguished road
Default Fuzzy logic boost controller... HELP.
Purchased a fuzzy logic boost controller... with no instructions. Can anyone help?
Here is the info on it. The litte control module says FBC (fuzzy boost controller) Made by Autolook Motor Sports. It has a computer box with a bunch of wires hooked up to it. A control module on a black wire and a bunch of hoses with a boost controller at the end.
Anything would help. Even instructions for a competing brand.
Thanks!!
smurfmods is offline   Reply With Quote
Old 10-06-2005, 10:19 PM   #2
smurfmods
Default Fuzzy logic
Anyone ever even used one of these??
Old 10-06-2005, 10:43 PM   #3
joel w
joel w's Avatar
there is no information on google about a company named autolook motorsports or auto look boost controllers that i can find in any combination of words? so no sorry
Old 10-07-2005, 12:41 AM   #4
smurfmods
Default Out of luck
Yeah, I tried google too. I can't find instructions for any other makers fuzzy controllers either.
May be out of luck.
Old 10-07-2005, 01:01 AM   #5
joel w
joel w's Avatar
is it just the module controller box only or do you have the vac solinoids also?
Old 10-07-2005, 06:22 PM   #6
smurfmods
Default hmmm
Not sure what a VAC selenoid is... may not have them. Is that going to make a difference? Do I have to have them?
There is a retangular box with some vac hose fittings. Looks similar to a manual box controller.
Old 10-07-2005, 09:38 PM   #7
joel w
joel w's Avatar
[QUOTE=smurfmods]Not sure what a VAC selenoid is... may not have them. Is that going to make a difference? Do I have to have them?
ya my bad, i misread you, it sounds like its complete setup. may have to open it to determin what wires do what? got to be some info on net somewhere? where did you get it?
i found this for an hks fuzzy controller? give you some idea
Install
•12-volt ignition power
•Chassis ground
•Input vacuum line from pressurized side of turbo to port 2 on stepping motor
•Output vacuum line from port 3 on stepping motor to wastegate
•Manifold pressure vacuum reference from intake manifold to port 1 on stepping motor
•Only the EVC Pro will require these additional wires to be run to the ECU:
•Speed sensor signal
•Tachometer rpm signal
•Throttle position signal
yours is probably similar but cant help much more,, here is that page i was looking at http://www.superstreetonline.com/tec...83/index4.html
Old 10-08-2005, 09:39 AM   #8
smurfmods
Default Fuzzy logic
I will try to post a picture of the complete setup today...
After taking a close look at the wires (only 6 or 7 long wires) and vac hoses I believe I may be able to get a start on figuring this thing out. With some help from everyone here I think we can do this.
That list does help a little. Gives me an area to start looking.
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
manual boost controller!!!!!!! justin1642 MKIII Supra 6 01-16-2007 10:01 PM
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
