#1 |
Not sure what a VAC selenoid is... may not have them. Is that going to make a difference? Do I have to have them?
There is a retangular box with some vac hose fittings. Looks similar to a manual box controller. |
#2 |
[QUOTE=smurfmods]Not sure what a VAC selenoid is... may not have them. Is that going to make a difference? Do I have to have them?
ya my bad, i misread you, it sounds like its complete setup. may have to open it to determin what wires do what? got to be some info on net somewhere? where did you get it? i found this for an hks fuzzy controller? give you some idea Install •12-volt ignition power •Chassis ground •Input vacuum line from pressurized side of turbo to port 2 on stepping motor •Output vacuum line from port 3 on stepping motor to wastegate •Manifold pressure vacuum reference from intake manifold to port 1 on stepping motor •Only the EVC Pro will require these additional wires to be run to the ECU: •Speed sensor signal •Tachometer rpm signal •Throttle position signal yours is probably similar but cant help much more,, here is that page i was looking at http://www.superstreetonline.com/tec...83/index4.html Last edited by joel williams; 10-07-2005 at 09:52 PM. |
#3 |
I will try to post a picture of the complete setup today...
After taking a close look at the wires (only 6 or 7 long wires) and vac hoses I believe I may be able to get a start on figuring this thing out. With some help from everyone here I think we can do this. That list does help a little. Gives me an area to start looking. |
Manual Boost Controller and Turbo timmer question | ethan12510 | MKIII Supra | 5 | 02-20-2008 10:54 PM |
manual boost controller!!!!!!! | justin1642 | MKIII Supra | 6 | 01-16-2007 10:01 PM |
ANY ONE EVERY USE A Apexi Boost Controller | donutking | MKIII Supra | 1 | 10-07-2005 01:58 PM |
installing manual boost controller 1989?? | hamburgler | MKIII Supra | 4 | 07-13-2005 12:55 PM |
