Old 04-18-2012, 05:51 PM   #1
2fast4u
2fast4u is on a distinguished road
Exclamation mk3 supra fuel filter
where would the fuel filter be located in a 1990 toyota supra turbo 7mgte engine with the r154 transmission and a lsd differntial. i heard that their is 2 fuel filters one mounted to the chasis above the fuel tank and one in the engine compartment. where would the one in the engine compartment be located. i checked online and it said its on the left side of the engine compartment but i cant find it. please help me thanks
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 04-18-2012, 06:31 PM   #2
There is only the one fuel filter. The only other thing along those lines is the sediment filter or sock on the fuel pump.
Old 04-18-2012, 06:32 PM   #3
Green7mgte
Supra Forum Moderator
are you talking about the filter on the fuel pump and then the actual fuel filter?
Im under the impression the mk3 has only one Fuel filter assembly. Near the rear.
I believe the 5m had its filter located in the engine bay, I could be wrong. (no first hand experience with a 5m)
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-18-2012, 08:23 PM   #4
2fast4u
Default Mk3 supra fuel filter
Iam talking about the filter on the engine compartment because I called Toyota and they also said that there's one in the engine bay
2 fast 4 u
Old 04-18-2012, 09:30 PM   #5
http://www.toyota-supra.info/forums/102436-post2.html
Old 04-18-2012, 10:27 PM   #6
Green7mgte
^ true story man.
you said you called toyota and they said there was a second filter inside the engine bay for your mk3 supra?
Supra FAQ
Supra MKIII FAQ
Old 04-18-2012, 10:32 PM   #7
btwilson86
Super Moderator
btwilson86's Avatar
I wonder if someone at the parts counter saw the vacuum surge tank (or whatever it's called) and assumed it's a fuel filter.
89 supra fuel pump. JWold MKIII Supra 6 12-31-2011 10:48 PM
1986 Supra fuel fliter location ricangsxrdude MKIII Supra 4 07-27-2008 11:50 AM
Fuel pump hanger for 87 supra non turbo rlipp69 Non-Generation Specific Questions 0 06-16-2007 03:23 PM
1991 Non-Turbo Supra: Use of K&N air filter to boost hp and mpg? unkymurch Non-Generation Specific Questions 2 04-02-2007 04:36 PM
