Old 04-23-2012, 02:01 PM   #1
phat_toaster
phat_toaster is on a distinguished road
Default Power Steering Blues
So I bought an '89 7MGTE a month ago, drove it over 700 miles from California where I picked it up, and then parked it. I was finishing my college career and didn't have the time for it. So yesterday, I decided to go on a Sunday drive, and the power steering pump seems to have disappeared. I have it parked over concrete and there's no evidence of leakage. Is it the pump?
'89 Supra Turbo Sport Roof, White on Blue
-3" Magnaflow Exhaust
-HKS Blow Off Valve
-GReddy Turbo Timer
-Tokico Illumina II Struts
phat_toaster is offline   Reply With Quote
Old 04-23-2012, 04:55 PM   #2
Have you actually checked the fluid level? Do so, add fluid if needed, turn the car on and turn the wheel to each side until it stops a couple times each directions to warm it up. Also wouldn't hurt to replace the belt.
Old 04-23-2012, 11:22 PM   #3
i havnt had much trouble with these pumps other than leakage.
do what cre said check fluid level and bleed.
http://www.cygnusx1.net/Supra/Librar...aspx?S=SR&P=42
Old 04-24-2012, 04:42 AM   #4
phat_toaster
Cool, and thanks guys. I'll be replacing struts on Wednesday, so I'll dig into it then and post an update.
-HKS Blow Off Valve
-GReddy Turbo Timer
Old 04-24-2012, 01:22 PM   #5
Green7mgte
Supra Forum Moderator
since were on the subject of PS. I wanted to ask the opinion of Lucas Ps treatment.
Im in the camp that doesn't like using fixes in a can. But I used this once on my moms eclipse. I think its more of a band aid then an actual fix. I wounder what problems it is actually making. Like burned out pulleys cause of the extra force due to higher viscosity on an already out of spec pulley.
Im not De-railing this topic Just saying if you were thinking of adding any of that it would be nice to know the pro's and cons.
Like I said I always try to fix something outright.. Most things in a bottle cause more harm then good, Just because the squealing goes away for a month dosnt mean its magically solved.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-24-2012, 05:18 PM   #6
Ranma
Ranma's Avatar
Am against all things that come in a bottle for a "quick fix". I was taught they do not work. While it may "work" for a bit, you are setting yourself up for failure. Then most of the people in this forum push their cars past their designed limits.
If one of them says to add some brake fluid to the transmission. Go ahead and hit them, it is a sure fire way to destroy it. Quality is doing thing right, shoody is doing things wrong because it is "cheaper". Actually in the long run doing it right is cheaper.
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
power steering problems.....any help? Preston MKIII Supra 3 01-14-2011 01:34 AM
No power steering 90supra MKIII Supra 1 11-01-2010 01:17 PM
Power Steering cables wet (leak) question rjSupra MKIII Supra 2 09-20-2010 11:34 PM
Power steering problem chinesedawn MKIII Supra 0 02-14-2010 11:20 PM
