Old 04-30-2012, 07:13 PM   #21
Joefishizzle
Joefishizzle is on a distinguished road
well im gonna have to get the denso O2 sensor from driftmotion when they get them in. i ordered the TPS and new TPS pigtail from them today so im gonna go back tomorrow and pick them up. ill let you know if that helps any of the codes. next will be the afm. i wish i knew people in my area that could swap one with me so i could test it.
Joefishizzle is offline   Reply With Quote
Old 05-02-2012, 03:47 PM   #22
Joefishizzle
well guys as shocked as i am the brand new oem toyota tps and tps pigtail from driftmotion fixed my issue. no more check engine. and the car is running awesome. idk but ya. those guys are awesome down there so anyone who can send them your support.
Old 05-02-2012, 04:08 PM   #23
Green7mgte
Supra Forum Moderator
we always do.. glad you got it sorted.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-16-2012, 07:01 PM   #24
Joefishizzle
Okay so very frustrated, the light came back on after numerous drives with no light after the new tps and connector installed. Again I checked codes and 21,41, & 51. How do I know which code is current and which are just stored?
I put the new Tps on and adjusted it, idk if I did that correctly however.
Im just confused and very regretful of buying this damn car. Plz help lol
Old 05-17-2012, 06:23 AM   #25
Code 51 won't cause the check engine light to appear under except while the ECU is in diagnostic mode. Improper TPS calibration will not cause a code 41 either.
Have you tested the wire harness? I would inspect and clean the ECU grounds and grounds from the battery. Test the alternator. Test the Vc pin at the ECU, the TPS, and the AFM connector; It should read 4.8v or so when the ignition is in the "on" position.
The ECU is still a possibility but unless you've got a known good one you can swap in to test with I wouldn't spend money on one without testing as much as possible first... Start with the cheap stuff or this car will sink you financially.
EDIT: Clear codes by removing the EFI fuse in the engine bay fuse box for 10 seconds or more.
Old 05-18-2012, 04:32 PM   #26
Joefishizzle
thanks cre for the speedy response, well i didn't do anything after the code came on. just parked it and went into work since i didn't have time to mess with it. came back after i was off and drove it home.....no code. hmmm.....well anyways while i was at work i decided to splurge and buy a new AFM since currently i work at a parts distributor and scored a reman one for 100 bucks out the door! way better than buying retail from vatozone, same part too!.
I went home with no codes on, installed the new AFM. started the car and wow what a difference. no more crazy surging idle. however the idle was up too 1500 and steady, so i re adjusted the tps and knock on wood the car has been running great the past day or so at about 700 to 800 steady idle. i will keep up on this and let you know if more codes continue under driving.
