Old 05-01-2012, 08:55 PM   #1
Nassol562
Nassol562's Avatar
Nassol562 is on a distinguished road
Smile 1jz on 87 supra??
i currently have a 87 supra with the 7mge and i plan to do a swap with a 1jz. i was wondering if it will be problem swaping the 7mge with the 1jz cause of the motor mounts??
Nassol562 is offline   Reply With Quote
Old 05-01-2012, 10:55 PM   #2
pandrade
pandrade is on a distinguished road
there should be somthing about this on the mk3 faq's
if an 87 i belive yes but you can buy motor mounts especialy made for the swap on pre 89 mk3's i know theres one swap on the faq's that has alot of info and pics
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
what do you think of this setup? Jareduhhhh MKIV Supra 4 02-19-2009 10:38 AM
