Old 05-03-2012, 01:42 PM   #1
2fast4u
2fast4u is on a distinguished road
Default mk3 supra intercooler lines leaking
hello whats the name of this hose so that i can order it becuase its wet and drips a little all the time. thanks heres a pic.
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 05-03-2012, 03:42 PM   #2
pandrade
its its there smaller two on the right thoes if im correct are the oil coolers soft lines, you can probably get them at advanced
Old 05-03-2012, 06:14 PM   #3
2fast4u
Default mk3 supra
how will i replace them or were can i get them besides the dealer
2 fast 4 u
Old 05-03-2012, 08:24 PM   #4
MJG
MJG's Avatar
Pull the lines off and take them down to:
American hose & fittings
19830 68th Ave. South
Kent
253 872 8080
Explain to them that they are oil cooler hose and you would like replacement (bulk) hose.
They can cut them to length.
Old 05-03-2012, 09:51 PM   #5
pandrade
i think if you go to any hydroulic's shop they will be able to make them for you, just explane what your needs are( as for a shop recomendation i cant help there im no where near you)
Old 05-09-2012, 06:34 PM   #6
Conga1991
Those hose lines are not for the oil cooler... they are for the power steering. If you follow where the metal pipe lines go to they should be bolted to the rack and pinion if im not mistaken.
mk3 supra intercooler 2fast4u MKIII Supra 4 05-03-2012 09:49 PM
Mk3 supra leaking oil 2fast4u MKIII Supra 16 03-18-2012 11:39 PM
87 supra brake lines wstanek MKIII Supra 6 05-15-2010 01:43 PM
1987 Toyota supra fuel lines wstanek MKIII Supra 2 05-15-2010 12:26 PM
