Old 05-21-2012, 03:19 AM   #1
Bloody Ben
Bloody Ben is on a distinguished road
Default 7MGE Starting Issue
I recent replaced the head gasket on my 91 n/a supra. It runs great now, except for when I cold start it. First thing in the morning when I start it it jumps to about 2000 rpm immediately and squeals from the belt slipping. Once its warmed up it will start just fine. Any ideas on what could be the issue?
Bloody Ben is offline   Reply With Quote
Old 05-21-2012, 03:47 PM   #2
Fix the squeal, check for diagnostic codes and make sure there are no intake leaks or vacuum leaks.
Old 05-21-2012, 05:18 PM   #3
Bloody Ben
It doesn't show any codes but I thought it could be a vacuum issue but didnt find anything. Any guesses on where the issue could be.
Old 05-22-2012, 03:51 AM   #4
iscv? idle speed control valve? did you take your TB off or mess with any of your cables recently?
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=106
in my experience, the only time I had high idle was when I took my throttle cable off and when re attached, it slipped and got snagged in a funky way. If you didn't remove any cables or adjusted them. recheck for leaks then diagnose your isc. yes on intake leaks also.. check around your accordion hose for unmetered air being sucked in. also on your intake plenum and lower manifold.
Tags
1991, 7mge, starting
87 7mge not starting Jrsinnovations MKIII Supra 6 09-18-2011 04:43 PM
1986 7mge supra not starting Jrsinnovations MKIII Supra 2 08-15-2011 07:05 PM
starting issue? brian white MKIII Supra 7 08-11-2011 03:46 AM
starting issue 88 supra automatic w/turbo help! ricerbaby MKIII Supra 2 04-15-2011 06:25 PM
Starting issue xAimz MKIII Supra 15 12-12-2010 02:56 PM
