Old 05-21-2012, 05:18 PM   #1
Bloody Ben
Bloody Ben is on a distinguished road
It doesn't show any codes but I thought it could be a vacuum issue but didnt find anything. Any guesses on where the issue could be.
Bloody Ben is offline   Reply With Quote
Old 05-22-2012, 03:51 AM   #2
Green7mgte
Supra Forum Moderator
iscv? idle speed control valve? did you take your TB off or mess with any of your cables recently?
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=106
in my experience, the only time I had high idle was when I took my throttle cable off and when re attached, it slipped and got snagged in a funky way. If you didn't remove any cables or adjusted them. recheck for leaks then diagnose your isc. yes on intake leaks also.. check around your accordion hose for unmetered air being sucked in. also on your intake plenum and lower manifold.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Tags
1991, 7mge, starting
87 7mge not starting Jrsinnovations MKIII Supra 6 09-18-2011 04:43 PM
1986 7mge supra not starting Jrsinnovations MKIII Supra 2 08-15-2011 07:05 PM
starting issue? brian white MKIII Supra 7 08-11-2011 03:46 AM
starting issue 88 supra automatic w/turbo help! ricerbaby MKIII Supra 2 04-15-2011 06:25 PM
Starting issue xAimz MKIII Supra 15 12-12-2010 02:56 PM
