Old 05-23-2012, 12:50 AM   #1
mic
mic is on a distinguished road
Default Timing Belt Case Replacement/Repair
My timing belt case is leaking coolant.
Has anyone installed TB case without removing oil pan successfully (no oil leak)? If so please explain your method.
Any ideas on repairing TB case crack or pit without removal?
Thanks to all.
mic is offline   Reply With Quote
Old 05-23-2012, 04:12 AM   #2
If you're referring to the lower, rear timing belt cover there are bigger things preventing you from pulling it.... The head gasket seals it at the top and because of the oil seals in it you can't slide it in and the up (in which case you'd still have to loosen the pan but you'll never get it to seal without pulling it and thoroughly cleaning it).
The short version you don't want to hear: pull head & pull oil pan.
Stripped Jumped Timing Belt batmmannn MKIII Supra 17 05-27-2010 12:48 AM
Timing belt questions..... Legionnaire MKIII Supra 0 09-17-2009 09:40 AM
New Timing Belt Direction Paul_NJ MKIII Supra 2 04-11-2009 01:16 AM
Replacing Timing belt Paul_NJ MKIII Supra 5 03-21-2009 05:35 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
