#11 |
Supra Forum Moderator
There are people pushing big numbers with the 7m
Would it be my choice? Look at 7mpowa.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#12 |
i belive reliability is a term not very specific, it relies on many variables motor condison, miles, oil changes, alot of other stuff. look at the bmw 2002 turbo i would consider that a unreliable motor becuase it has facts that show it would run like a champ if you fixed it every day, i have NEVER seen an unreliable toyota motor( some might be desighned in wierd ways yes) every toyota iv owned and worked on has lived to be about 250k miles at least. i know the 7mgte wasent built to be a full race motor so i dont expect it to be worry free at 1000hp but i bet the 2j wasent eather, any thing can be built to be reliable and fast for the correct fee
![]() ( i would like a 2j in mine just because parts are much more common)
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come |
#13 |
nothing wrong with a 7m but i t was only designed to push so much power and hold so much compression. there is just alot of things not designed to hold the rpms and power. lets start with the rods. ive seen alot of stretched rod bolts and bearing failures in stock 7m engines.
all im saying is why not start with an engine that was already designed to hold a higher power output. agreed on the fact that inline engines are good. ive had many myself. but my 5mge and 7mge's that i have had use more fuel and make less power than most of the v8s ive had. i just no longer see the point.
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#14 |
ask what it cost them. compared to a v8 with a intake and carb. or ITB's
#15 | ||
![]() Quote:
#16 |
not saying I would. just it is possible.. practical? your call.
IMHO I wouldn't take my 7m past 500 Bhp. granted I could even get it up that high reliably. (with my skills, mind you.) More of a reality for me would be around 350 on my 7m with minor overhauling.
#17 | |
![]() Quote:
there is 5 mk4 twin turbos all over 15k... but you also have to take into account the milage most mk3s have already undergone... just talkin... not try to down anyones ideas dont get me wrong...
#18 | |
lol here i was thinking u where saying some one went 1000hp whith factory rods, my bad
7mgte, replaced head gasket, turbo, not cranking | 87supra7mgte | MKIII Supra | 17 | 06-25-2011 11:36 PM |
7mgte head gaskets | Jay633 | MKIII Supra | 2 | 06-04-2011 05:30 PM |
$2000.00 FIRM - 1990 Toyota Supra (targa, 7MGTE) - Bad head gasket | Grandavi | Buy/Sell Cars | 1 | 05-31-2011 11:22 PM |
1992 7mgte overheating and blowing head gasket | drewmiller5007 | MKIII Supra | 5 | 07-04-2010 09:24 PM |
7mge head same or not from 7mgte | demon2supra | MKIII Supra | 4 | 05-31-2007 07:38 AM |
