Old 06-04-2012, 12:44 AM   #1
1989toyotasupraandpickup
1989toyotasupraandpickup is on a distinguished road
Default TPS voltage problem
So here is the story. i own a 1989 toyota supra turbo. the problem i am having is the voltage at idl and e2 at the ecu. When i probe these leads i get 10 volts instead of the 4-6 that toyota calls for. when i unplug the ect for the transmission the voltage across idl and e2 drops to 5.2v. this is where it is supposed to be. Anyone know what the problem may be.????? please someone help i am ripping my hair out wondering where the problem may lay. thanks
1989toyotasupraandpickup is offline   Reply With Quote
Old 06-04-2012, 10:27 PM   #2
Anyone??????
Old 06-04-2012, 10:44 PM   #3
if its faulty, replace it bro
Old 06-05-2012, 02:27 AM   #4
thats the thing i dont want to pay for something i dont need. im going to run it how it is. it runs ok just runs rich but that may be because i had the battery disconnected for a few days. only had it idle in the garage. the computer needs to relearn the fuel pattern.
Old 06-05-2012, 06:55 AM   #5
Measure the resistances across the TPS connections as detailed in the EFI section of the TSRM. Disregard the info you have concerning the voltage, if you look in the ECT section of the TSRM you'll find it specifies approx 4v.... The ECT computer pulls the voltage down, a manual equipped 7M should have 10v to 14v. It's pretty broad as it's not there to give any signal beyond on/off.
A bad IDL switch isn't going to cause you to run rich either.
Old 06-06-2012, 03:37 AM   #6
thanks cre. what would cause the car to run rich?
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
