Old 06-11-2012, 07:46 PM   #21
akue
akue is on a distinguished road
The ground from the.engine its gotta be somthing for a ground I'm not even getting a spark.
akue is offline   Reply With Quote
Old 06-11-2012, 08:35 PM   #22
Ranma
Ranma's Avatar
Talking
There is a strap for engine grounding come to think of it. Did you restore power to the rest of the car?
Old 06-11-2012, 10:41 PM   #23
akue
Nope none of the car has power yet the one cable that was on the engine was barly on and the one that grounded to the frame is fine all I can see is the ground that went to the engine and fram and I fixed the ground to the frame but yet I still have no power
Old 06-11-2012, 11:52 PM   #24
akue
Where is the ground for the alternater
Old 06-12-2012, 12:37 AM   #25
akue
Now thag I think of it if I have the grounds from the batter both on the frame of the car will that even work? The ground that was to the engine should be on the engine right?
Old 06-12-2012, 02:11 AM   #26
Ranma
Ranma's Avatar
Are you sure the battery has power? If it is dead nothing you do will help. you can get a light bulb from the car and put the 2 wires on the post or you can set it up for a jump start or battery pack. The first thing in line is the battery and when troubleshooting electric start at the source.
Old 06-12-2012, 02:29 AM   #27
akue
Yea the battery has power we tried jumping the car wouldn't work I have a battery tester and it said the battery full soo I have no idea wtf is going on I cant get anything to work
Do you know where the alternater ground wire is so I can look at it? Only wire I have found of ground is the battery ground that goes to the engine itself tried seeing if that was the problem but still no power tomorrow I'm getting the 30 and 40 amp I. The engine bay fuses replaced see if that changes anything
Old 06-12-2012, 04:30 AM   #28
Ranma
Ranma's Avatar
Ok is their power to the battery side of the fuses? Next check the other side then head to the fuse box. Oh yes the alternator ground goes to the battery.
Anyhow check the wires for corrosion. They look good on the outside but may be broken in the middle. First try seeing if the wires have electric. If the battery side of the engine fuse box has power it is not the ground. Check the wire from the battery to the fuse box.
Old 06-12-2012, 04:33 AM   #29
btwilson86
Super Moderator
btwilson86's Avatar
There is no ground wire to the alternator.
Do you have jumper cables? If so, you can use them to bypass your ground wire. Take the negative battery cable off of the battery. Hook one end of the jumper cwble to the negative battery post. Now hook the other end of the jumper cable to the engine (a good place is the hook used for pulling the engine, right next to the alternator). Still no power? Move the jumper cable from the hook to a bolt on the body of the car. If you still have no power after this, then the negative battery cable is most likely NOT the problem.
To diagnose further, you really need to get a multimeter, or at least a test light. Without the proper tools, nobody here will be able to help you.
Old 06-12-2012, 08:09 AM   #30
akue
How would I sheck if the fuses have power
I feel like I'm no help at all like I really have no.clue wtf I'm doing I'm just looking at anything that looks wrong just weird how my car just died like that and when I was taking the postive cable off my car got some power to turn the lights on 2 times but just stoped and cant find the problem just stumps me
mk3 supra power steering fluid 2fast4u MKIII Supra 14 04-16-2012 01:29 PM
Supra slow to pick up power downunder MKIII Supra 7 03-02-2011 11:49 PM
94 Supra TT with idling and lost of power issue bayatt MKIV Supra 4 03-12-2010 01:29 PM
1991 Non-Turbo Supra - Power Antennae Replacement Options unkymurch Non-Generation Specific Questions 2 04-29-2007 06:35 PM
