Old 06-24-2012, 01:47 AM   #1
carl johansson
carl johansson is on a distinguished road
Default can you add Trans fluid through top - W58?
Can you add trans fluid to the W58 through the shifter hole in the top. i've done it through the side hole before, but it was a PITA. it would be real easy to just dump it in through the hole before I put the shifter back in.
and something like 80 W 90 oil? right
carl johansson is offline   Reply With Quote
88 Turbo, issues with Auto Trans Staceman MKIII Supra 5 08-13-2007 09:51 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Auotmatic trans. questions Al Hanks MKIII Supra 1 03-15-2007 12:44 AM
Trans Mount Change mrnickleye Supra FAQ 0 02-20-2007 05:24 AM
tranny fluid tone loc MKIII Supra 9 10-23-2006 04:06 AM
