Old 07-06-2012, 09:21 PM   #1
Ghostpopi
Ghostpopi's Avatar
Ghostpopi is on a distinguished road
Default 88 supra got a problem
i have an 88 supra not turbo. So i've been reading these forum for awhile, but not found answer to this problem.
My problem is when car gets hot an stop turn it off. then get back in it an turn the key, she will turn over an over but not start. but if i let it sit for what feels like 4ever she start right up.
previous owner said his mechanic told him the ignition control module has getting hot an not starting the car but once it cool down it was fine.
Is this correct? is this a common problem with supra's? cuz the part is $400 bucks an i don't have $400 buck jus toss at something that might not even be the cause.
Any help be greatful, thank you.
Ghostpopi is offline   Reply With Quote
Old 07-07-2012, 01:05 AM   #2
See the FAQ section for info on how to check for diagnostic codes stored in the ECU. No, it is not a common problem and you should not blindly throw money at it, you'll be broke in a week if you get in that habit.
1994 N/A supra computer problem. tecnorobo MKIV Supra 2 08-28-2011 11:28 PM
89 Supra problem rs2800 MKIII Supra 0 06-26-2010 09:59 PM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
supra rear axel problem supradude85 Non-Generation Specific Questions 1 05-18-2005 12:26 PM
MK3 supra cooling problem HELP!!! Jazza22 MKIII Supra 8 02-02-2005 05:49 AM
