Old 07-05-2012, 09:13 AM   #1
lmmr74
lmmr74 is on a distinguished road
Default Compression Test
Hello, i just did a compression test on my 89 Supra Turbo (7M-GTE), and i got the following results:
Cylinder 1 12.5
Cylinder 2 10.5
Cylinder 3 11.5
Cylinder 4 10.5
Cylinder 5 11.5
Cylinder 6 12.5
Can someone help on these numbers?? Are these ok? I am confused because on the technicall manual, it says taht minimum compression is 9, and normal is 10 or higher, on the other hand the guy in the auto store told me that should be around 8.4...
Thanks in advance for your help!!
lmmr74 is offline   Reply With Quote
Old 07-05-2012, 11:16 PM   #2
The guy at the auto store doesn't have all the info or is just basing that number off his experience with different engines.
The high numbers is most likely due to carbon buildup in the cylinders. The only are of concern is the high difference in compression between neighboring cylinders. I'd recommend either steaming the cylinders or running some Mopar Combustion Cylinder Cleaner through it (follow the directions).
Compression Test Results Wileyk24 MKIII Supra 1 03-12-2012 02:40 AM
Weird compression test - is this a BHG?? zyzx2k9 MKIII Supra 2 06-19-2011 02:00 AM
compression test question mastergrader007 MKIII Supra 2 08-09-2008 12:05 AM
WOW did a compression test now i got code 12 n 14 help 88Tsupra MKIII Supra 9 06-30-2007 08:19 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
