#1 |
Hi all,
Long time forum creeper, first time poster. After months of research and shopping around for the right car, I recently purchased my first Supra. (Finally got my dream car! ![]() The car had an electric radiator fan to replace to the primary fan when I got it. The two smaller fans were included, but not hooked up. After I drive the car, it gets really hot in the engine bay, and I have yet to have the fan actually come on while driving that I've noticed. (My temperature gauge in the dash comes up about halfway.) I think the previous owner wired the fan to the aux thermostat, which, from what I've read, doesn't turn on until about +225* F? This seems way too hot for me. There is some crazy wiring going on under the hood anyway, and I think the fan may be pulling my battery down because it dies after a couple days if I don't crank the car and let it idle for a bit (why is there no battery gauge in the dash!? ![]() But anyway, I'd really like to go back to a mechanical fan. It just seems so much simpler and reliable, but I don't want to turn this into another "which is better" thread. I've read about the clutch flex fans, but all I can find are the flex-a-lite fans, which are electric. If anybody can help me find somewhere I can purchase a mechanical flex fan, I'd greatly appreciate it. I'm also going to need the clutch for it, and a shroud. If I can't find one, I may just have to go back to a stock fan. Thanks in advance for all help and advice! |
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
http://www.summitracing.com/search/B.../?autoview=SKU
http://www.jegs.com/p/Flex-a-lite/Fl...44311/10002/-1 They're pretty easy to find actually. I've posted links to other manufacturers and shops in the past, you might find them if you search the forum but it's nothing special. As for the fan shroud, Perma Cool, Flex-a-lite and other manufacturers make extensions which will move the fan forward into the proper location for the stock radiator shroud.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
I stumbled across some of those yesterday, but I was unsure about them because I'm not sure what fitment I need. I guess I expecting one to be specified for a mk3 Supra. I just measured the fan I currently have on my car and it's 14" diameter and 1.5" wide, but it mounts directly on the radiator since it's electric. Also, I'm pretty sure the radiator that's on there isn't the original, although it may still be OEM, not sure. Will this affect anything?
Also, I'm not sure what clutch to look for either. From what I've heard, a factory fan clutch won't work with these flex fans right? Are the clutches specific to each fan model? And thanks for your advice about the extensions. I guess the size of the extension I need will vary depending on which fan I decide to go with, but how will I know how close the fan needs to be? I don't have the factory shroud to use as a guide. ![]() |
#4 |
IT's an easy enough equation. You want to measure from the innermost side of the radiator to the mount on the water pump. Now deduct one inch. That's the maximum you can go including both fan, clutch and spacer. Manufacturers and shops should list the dimensions for most of the products online.
As for the fan diameter, you'll need someone to measure and provide you with the diameter of the fan shroud's primary opening at its NARROWEST POINT. The fan shroud is a two piece unit and you should get the measurement with the second lower piece installed. Again deduct one inch and that would be the maximum fan diameter I would use... I might be inclined to go just a little smaller yet. All in all not too difficult of a project, just need the one measurement from the shroud which you don't yet have and you should be good to go.
#5 |
I had one of those flex fans with out a clutch and it was super loud and made a winning sound also felt like it was stealing a lot of power from the motor and cause the belt to slip. so I would use a clutch. I switched to dual electric fans with its own thermo switch set at 200 Plus a 2 row radiator. Also i upgraded my alt to a 140amp to help run the fans. Here is every thing needed to go back to stock not cheap.
Fan http://store.driftmotion.com/static/...tefanblade.php Fan clutch http://store.driftmotion.com/static/i-7mfanclutch.php Shroud http://store.driftmotion.com/static/...supra86-92.php |
#6 |
Yeah, you should never run a mechanical fan without a clutch, factory or otherwise. You're lucky it didn't come through your hood.
Thread Tools | |
Display Modes | |
