Old 07-21-2012, 07:03 AM   #1
crazyfj40
crazyfj40's Avatar
crazyfj40 is on a distinguished road
Default 86.5/ 90 supra turbo
ok gang just bought a 1990 supra n lookin at ,makin my 86.5 supra an 86.5/90 supra with turbo the 1990 has factory turbo so i have all the parts n electrical so soon ill have a nice supra with factory turbo n it will be an 86.5 with newer motor n trans n rear end so what ya think
Dan
crazyfj40 is offline   Reply With Quote
Old 07-23-2012, 06:37 PM   #2
Might want to try repeating the question again... with some grammar sprinkled in.
Old 07-23-2012, 11:25 PM   #3
i think he is asking for an opinion.
example:
i have an 86.5 non turbo supra, that i want to smash in a 1990 7mgte and electronics into. as well as trans., and rear diff. will i experience problems? or perhaps custom fabrication??
Old 07-25-2012, 06:49 AM   #4
Thanks, CanadianBak'inSupra. I kind of thought that was the case but
Fix the '90, the swap's going to suck. If you're dead set on swapping then just plan on swapping EVERYTHING (including the dash and chassis wire harnesses). If you don't have everything I strongly recommend you consider getting a hold or pre89 wire harness and electronics for the engine.
There are a thousand little things which will make this project tiresome. If you can gut the '86.5 first and then literally install the parts from the '90 as you pull the from the '90 it'll go a bit easier but still expect snags and things you didn't realize were different: 89+ has different motor mounts, different oil pan, different cross member, 2 small electronic aux fans (which pre89 aren't wired for), GTE has a hidden electrical fan between the radiator and a/c compressor, GTE has an oil cooler.... etc...
Old 07-25-2012, 04:25 PM   #5
actually I wanted crazyfj40 to reply but your welcome.
the swap is possible. but your car is going to be off the road for a while.
Old 07-26-2012, 02:40 PM   #6
crazyfj40
crazyfj40's Avatar
Actually you are correct Canadian in that is what i was asking about. Being the redneck that i am i sometimes take the long way around to my questions lol. now that being said i did plan on the cars being down for awhile. i plan to gut the 86.5 first then start on the 90. The reason i dont put the 90 together is no title and i dont wanna fight with it
Dan
86.5 supra
87 supra
90 turbo supra
70 fj40 sprung over,35" bfg all terrains locked rear end sm420 swap full cage
79 toy Pickup wifes toy 35" tires locked in the rear buick v6 auto trans
89toy pick up
84 fj60
85 fj60 will be gettin a 3fe conversion soon n regeared
91 fj80
95 fj 80 350 chev conversion built for overland travel
K7DWG Dan
89 supra turbo targa top 500hp all new mods! Little rock, ar marcmann982 Buy/Sell Cars 3 12-15-2011 10:52 PM
Installation of T61 turbo on a mkiii supra ahruizguerra MKIII Supra 1 12-02-2010 11:19 PM
*SOLD* - 1994 Toyota Supra Twin Turbo - 2JZ-GTE 6spM - RARE!!! SupraPhan Buy/Sell Cars 3 11-24-2009 04:15 AM
Did they make an original single turbo supra (1994)? ts1994 MKIV Supra 3 07-20-2006 08:18 PM
