Old 08-05-2012, 01:50 PM   #1
Sonyps307
Default Pillow ball top mounts.
Ok so I got all new suspension parts springs, shocks, upper and lower ball joints and bushings all around for my supra. Also will be lowering it with H&R spring with tokico blues. So the H&R's will lower the front by 1.6" and the rear by 1.3". So I'm asking will I need adjustable pillow ball top mount to get the camber back to stock so I don't get a lot of tire wear. But the problem is that I readed that the pillow balls give u harsh ride.
Old 08-05-2012, 05:54 PM   #2
There's a lot of room for adjustment in the MKIII and I know a lot of people who've run significant drops that didn't need additional hardware to get the camber dialed in. I think you should try it without them first.
Old 08-05-2012, 08:46 PM   #3
Sonyps307
Ok on that note I will just get some stock replacment top mounts and save some money. The suspension on my supra look to be original beside the front struts. Lol sound like I got basket balls in the rear when hitting bumps fast.
what size pickle fork opening for ball joint replacement rjSupra MKIII Supra 3 03-03-2011 11:17 PM
ball joints jcastro MKIII Supra 5 08-25-2010 04:15 PM
Tie Rods & Ball Joints mrnickleye MKIII FAQ 1 03-10-2007 04:50 AM
Motor Mounts chrisr3344 MKIII Supra 1 01-30-2006 02:54 AM
