Old 08-06-2012, 05:45 AM   #1
icey756
icey756 is on a distinguished road
Default What rings should I get?
Im in the process of reassembling my engine. I honed the cylinders and I am replacing the rings. stock bore. Every time i search all that pops up are the NPC. They are pretty cheap so thats why I'm skeptical. I found some CP rings for 130 but I dont really know if i need to spend that much. I just dont want to end up getting crappy rings and tearing the engine apart agian. Any help would be great.
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
icey756 is offline   Reply With Quote
Old 08-09-2012, 12:03 AM   #2
icey756
So no one can tell me anything about what rings are good and what rings are bad?
Old 08-09-2012, 12:40 AM   #3
From my experience there's nothing wrong with NPC. They're fine for a mildly built engine. If you're looking for a lot of power get over the price and forget about cheaping out on any internal components. They're pretty much OEM quality. I've never noticed any machining flaws or inconsistencies in any of the sets I've installed.
Old 08-09-2012, 01:56 AM   #4
icey756
do u think a set of the npc's would be ok then? cause if i get that set i get rings, pistons, and connecting rods
edit: Ill just get the NPC rings. Just rings for 44 bucks. As long as you havent had a problem with them i dont see why i would either
Old 08-09-2012, 07:01 AM   #5
Their pistons aren't bad either but again don't expect them to withstand anything the stockers wouldn't be able to handle. If you can find them you can get them with a ceramic coating on the crown or you can get a plain set coated for some extra durability. But like I said, if you're looking for bigger numbers do it right the first time or do it all over again in 6 months. If you look around you'll find they're quite popular for all makes out there... There are a few big threads about them on SM and SF. Not many people have had problems with them until they start really pushing things hard.
Old 08-10-2012, 02:03 PM   #6
icey756
hey cre i was also wondering if there is any pressure behind the rear timing cover. I would have to assume there really isnt because from there it goes up into the head
Old 08-11-2012, 02:18 AM   #7
Enough pressure to create a very nasty oil leak if you forget to place packing/FIPG where the plate meets the head and the HG sits on top (see: TSRM > Engine Mechanical > Cylinder Head). I don't see how it would see the full pressure of the oiling system but it does have some pressure.
Old 08-11-2012, 04:36 PM   #8
if your talking about this:
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=55
i know someone who did not apply sealant and he had problems.
Old 08-12-2012, 06:31 AM   #9
Oh, I made that mistake myself once.... ONCE. It's a terrible reason to have to redo a headgasket job.... granted it's MUCH easier the second time it's still not worth it.
Old 08-12-2012, 07:32 PM   #10
lol the third time should be no problems then. only one way to learn, lots of reading or lots of mistakes
putting in new piston rings johnvin MKIII Supra 12 05-07-2011 07:22 PM
piston rings which ones to get? Clorox9 MKIII Supra 0 06-14-2009 04:35 PM
What type of Rings for NOS? abhattan MKIII Supra 1 03-20-2008 11:27 PM
Bhg vs worn rings vs valve guides Kuban MKIII Supra 22 04-23-2007 02:18 AM
1jz & 2jz Piston Rings joolhamdi MKIII Supra 4 04-14-2006 02:44 AM
