Old 08-10-2012, 04:41 PM   #1
phat_toaster
phat_toaster is on a distinguished road
Default Washer fluid pump?
So I've scanned the TSRM and can't find anything that relates to the washer fluid pump, and I'm having trouble tracking down a replacement pump. By my inspection, it looks like there's two pumps at the bottom of the reservoir, one for the front and one for the back. The one for the front is burnt out. Has anyone fixed or replaced one of them before and where did you find a new one? Thanks!
'89 Supra Turbo Sport Roof, White on Blue
-3" Magnaflow Exhaust
-HKS Blow Off Valve
-GReddy Turbo Timer
-Tokico Illumina II Struts
phat_toaster is offline   Reply With Quote
Old 08-11-2012, 02:10 AM   #2
85330-50020 MSRP is about $30.
You can source one used from a like year Camry, Celica, 4Runner, Land Cruiser or Tercel.
Old 08-11-2012, 04:01 AM   #3
907mge
907mge's Avatar
If you still need one, I have a couple used.
Old 09-12-2012, 03:24 AM   #4
phat_toaster
I found a new pump, but which one sprays the front and which does the back? The lines disappear so I can't trace them.
-HKS Blow Off Valve
-GReddy Turbo Timer
Old 09-12-2012, 01:41 PM   #5
907mge
907mge's Avatar
I would think the front would go to the front but I could be wrong. If you want to be absolutely sure. Just disconnect one of the lines and run the pump. You will know for sure that way which is which. Atleast it doesn't have headlight squirter or you would have 3.
Old 09-12-2012, 02:14 PM   #6
phat_toaster
it's not a matter of one on the front and one on the back, they're side by side on the reservoir. and the lines go up into the fender together. i'll just have to run the pump i think though, like you said. unless somebody else knows off the top of their heads?
-HKS Blow Off Valve
-GReddy Turbo Timer
no power to fuel pump carcrzy920 Non-Generation Specific Questions 0 06-05-2009 05:51 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
power steering pump blowing fluid carl johansson MKIII Supra 1 11-24-2007 06:34 PM
Window Washer Fluid AssassinSM MKIII Supra 1 08-31-2006 08:38 PM
