Old 08-11-2012, 02:06 AM   #1
mpaulen
mpaulen is on a distinguished road
Default 88 supra 7mge to 7mgte questions
Hello I am new and just bought my 88 supra it has 45k original miles and is auto though not a fan of auto so i am wondering for the swap whats the cost i found the engine here, http://www.japangeneralmotor.com/ind...-engine-1.html
Which it seems is the cheapest place for engine and 5 speed. Is that the best JDM site?
What else would i need and the cost be?
Thanks
mpaulen is offline   Reply With Quote
Old 08-11-2012, 08:28 AM   #2
mpaulen
What else would i need besides that ECU and wiring harness?
http://www.jdmtigerjapanese.com/toyo...ion-89-90.html
or
http://www.bestofjdm.com/JDM-ENGINE-...dmtoyota10.htm
not sure which is the best place to buy from
Old 08-11-2012, 06:51 PM   #3
S-mk3-B
S-mk3-B's Avatar
S-mk3-B is on a distinguished road
Try this place, http://www.jdmenginezone.com/
I recently just swapped my 7mgte and this is where I got my engine from. They gave me a good condition engine and they're BBB certified as well.
S-mk3-B is offline   Reply With Quote
Old 08-11-2012, 07:12 PM   #4
mpaulen
They have a good engine price but I'd want the manual too, so i was looking for that to add on.
Know anything about these guys?
http://zerolift.com/products/toyota/...urbo-full-swap
Old 08-12-2012, 07:30 PM   #5
What is required has been discussed thoroughly on this forum in the past and doesn't merit repetition. If you're having trouble finding appropriate results with the search function let me know and I'll help you dig up some threads. (Yes, I really need to get a concise thread put together for the FAQ section... So little time...)
I don't know anyone who's purchased a JDM engine for a MKIII from any shop other than DriftMotion recently. I don't recommend JDM engines. Particularly when an engine reaches this age it's most likely in need of a full rebuild regardless of mileage. Save the money on shipping, buy locally and save yourself the headache of figuring out what's different in the JDM 7M-GTE and trying to then locate those missing components locally. A 20+ year old engine is a 20+ year old engine.
Getting an engine, electronics and transmission of the same year or revision as your car ('87 or '88 in your case) will save you a good amount of hassle too. Otherwise you're likely to need to swap subframes, sensors, oil pans, patch even more wiring and so on.
If possible getting a complete front clip or a complete donor vehicle will be a great help too... This way you get all the mounting brackets, the intake plumbing, the oil cooling system and so on.
Old 08-13-2012, 03:41 AM   #6
mpaulen
Thanks a ton!
7mge to 7mgte REBUILD QUESTIONS ochowdero MKIII Supra 11 10-28-2011 05:48 AM
My '87 Supra 7MGTE, Newbie Questions suav MKIII Supra 7 04-10-2007 04:49 AM
