Old 09-05-2012, 02:18 AM   #1
pandrade
pandrade is on a distinguished road
Default code 34 fixes
so from looking at the FAQ's and some other threads i have concluded that code 34 is abnprmal turbo pressure. Im gussing the fixes to this is to check all the hoses in the charging system and intercooler to make shure they arent leaking boost. this has never happend untill just recently when i put in a new clutch so im gussing i might have losen a coupling or pulled a hose and havent noticed
so far besides the code the car is geting worse milage, loss of power, and when i go into full boost on and off( like at autocross) it feels like its being shut off by the computer and seconds later it keeps going like nothing has happend.( does this in a sputering motion but only under heavy boost and aggressive driveing)
my questing is does what i know sound about right if not can you guys correct me
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
TPS code 41... Cyberguy1992 MKIII Supra 0 04-26-2011 08:14 PM
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
Well... Another code.. Cyto MKIII Supra 1 02-02-2010 12:21 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
