Old 08-31-2012, 07:28 PM   #1
phat_toaster
phat_toaster is on a distinguished road
Default horn doesn't work
My horn doesn't work when I push the steering wheel. It works all too well when the alarm goes off though, so it's got to be a wiring issue. I figure it'll come down to pulling out my volt meter, but I thought it'd be worth a shot to see if anyone has already found the solution and if it's a common problem. Anyone? Thanks!
'89 Supra Turbo Sport Roof, White on Blue
-3" Magnaflow Exhaust
-HKS Blow Off Valve
-GReddy Turbo Timer
-Tokico Illumina II Struts
phat_toaster is offline   Reply With Quote
Old 09-02-2012, 04:38 PM   #2
Two different horns. The alarm's horn is by the brake booster and the hazard horn is in front of the radiator. So, check the horn fuse and relay and the test wiring if needed.
Dome Lights btwilson86 MKIII Supra 6 04-03-2011 01:05 PM
Dome Lights btwilson86 MKIII FAQ 3 04-03-2011 01:05 PM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
