Old 08-26-2012, 06:36 PM   #1
1986.5SupraOwner
1986.5SupraOwner is on a distinguished road
Exclamation Need help with 86.5, 7M-GE. Won't start, has power, does turn over.
Hello !
So everyday when I first go to start my car , I put my key in the ignition and turn it to on and everything works , so then I turn my car on and it all goes quite and nothing happens ... I hold my key in the on position for 5-10 seconds then it start to click and try to get up past 1k rpms but stays in the 500's for a bit ( my key is still turned to the start ) then finally I let go of my key and it slowly jumps up to 2k rpms then back down to 1k then im good to go. Could anyone please! help me out and try to diagnose the problem?
Thanks!
1986.5SupraOwner is offline   Reply With Quote
Old 08-26-2012, 07:26 PM   #2
1986.5SupraOwner
Default Anyone?
Please could anyone give me some advice on what to do ? Im lost
Old 08-27-2012, 02:00 AM   #3
This isn't the busiest of board. I usually check in frequently, but I've had house guests for a few days.
Start with checking for diagnostic error codes stored in the ECU. There is a thread explaining the process and listing what all the codes are in the MKIII FAQ section.
Also, when posting new threads make sure the title is descriptive. A lot of people just ignore threads if they don't know what it's about. And lastly, always post the specs of your car or put them in your profile signature so it shows up in your posts. If this car is a non-turbo there is a whole set of possibilities which aren't considerations with the turbo model and vice versa.
Old 08-27-2012, 02:08 AM   #4
1986.5SupraOwner
Default Thanks for the Reply
I realized my title wasnt to great right after I made it :/ but thanks Ill go take a look at the code threads , and will update my signature right now!
Old 08-27-2012, 02:13 AM   #5
I've updated your thread title with what I think is the correct info. Also, don't just add your car's specs to your profile but also put them in the signature so they show up in all your posts and people who are trying to help don't have to dig at all.
Old 08-27-2012, 02:34 AM   #6
1986.5SupraOwner
Default Thanks
Thanks alot ! Im still new to this all , this supra is my first car and I sure messed up with buying it :s
1986.5 Toyota Supra non turbo
7M-GE
Old 08-27-2012, 06:05 AM   #7
Ok, well, here's a forum usage/etiquette crash course:
Read the descriptions of each forum before posting so you know you're in the right area. Check the FAQ sections for information about common problems and technical and troubleshooting information. Always use the search engine to see if your problem or similar problems have been posted by people in the past (as old as these cars are, few problems are unique and the solution has often been posted a couple times before). Read any stickies in the forums for information on how to best use the forums to your advantage with minimal headache.
MKIII FAQ section: http://www.toyota-supra.info/forums/mkiii-faq/
Old 09-04-2012, 05:45 AM   #8
87hilux7mge
87hilux7mge's Avatar
sounds almost like and afm prob or maybe low fuel pressure. if its turning over fine. if the starter isnt engaging or turning at all id look for corrosion, high resistance or a worn starter.
Tags
help!, supra, supra problems
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
No power and Starter won't turn supraturbo_mk3 MKIII Supra 7 05-23-2011 03:57 AM
86.5 Manual non-turbo will not start!! tcrawman MKIII Supra 7 03-31-2008 09:13 PM
Hard to start / no power wsnipe Non-Generation Specific Questions 3 01-22-2007 08:18 AM
Won't start, but has power KNYFE MKIII Supra 3 03-30-2006 12:02 AM
