Old 09-05-2012, 02:18 AM   #1
pandrade
Default code 34 fixes
so from looking at the FAQ's and some other threads i have concluded that code 34 is abnprmal turbo pressure. Im gussing the fixes to this is to check all the hoses in the charging system and intercooler to make shure they arent leaking boost. this has never happend untill just recently when i put in a new clutch so im gussing i might have losen a coupling or pulled a hose and havent noticed
so far besides the code the car is geting worse milage, loss of power, and when i go into full boost on and off( like at autocross) it feels like its being shut off by the computer and seconds later it keeps going like nothing has happend.( does this in a sputering motion but only under heavy boost and aggressive driveing)
my questing is does what i know sound about right if not can you guys correct me
Old 09-05-2012, 03:18 PM   #2
You're right. A boost leak is the most common cause of this code.
Old 09-05-2012, 08:29 PM   #3
pandrade
today i have taken all of the hoses in the charging system and have found all to be in operable shape and in over all good condison, what else could be causeing this problem? when driving if i stay in -4 boost area i have no issues as soon as i give a little more gas and hit 0 it feels like it drops in power and torque. the most at full throttle i can get is 5psi and it feels nothing like full boost use to a few months ago could this be an electrical problem since all the hoses are ok?
Old 09-06-2012, 03:11 AM   #4
Test the BOV to be sure it's not leaking boost. Inspect the wastegate actuator (make sure it's not sticking and keeping the wastegate open. Inspect the turbo.
Old 09-06-2012, 02:15 PM   #5
pandrade
the bov is good( i tested it by trying to blow air through it and it wouldent allow air throught) now to test the actuator should i just pull the little arm and see if it has a full range of movement? oh and lately around when this problem has started i would get a big puff of blue smoke on start up, it always did this but since this code and problems started rearing its ugly head its been getting more common( at this point is at every start up)
Old 09-07-2012, 06:12 AM   #6
Blue smoke when starting cold would most likely be valve stem seals leaking... but it wouldn't hurt to be sure something bigger isn't wrong (rings, hole in a piston, leaking HG).
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
TPS code 41... Cyberguy1992 MKIII Supra 0 04-26-2011 08:14 PM
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
Well... Another code.. Cyto MKIII Supra 1 02-02-2010 12:21 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
