Old 09-18-2012, 07:13 PM   #1
91e30325i
91e30325i is on a distinguished road
Default Noob with some questions
hey i guys i bought a 1989 mk3 7mgte from my brother. he bought it with a blown head gasket a few years ago fixed it then life happened and it sat in our garage for a couple of years.
a couple months ago i decided i wanted to get a track car so i bought it and have done some work to it but it is having a fuel cut problem. i installed a 2.5" straight pipe from the turbo to the back of the car, but whenever it gets around 3k revs it starts cutting out.
is this an injector problem, a fuel pump problem or something else
thanks in advance
91e30325i is offline   Reply With Quote
Old 09-19-2012, 02:24 AM   #2
Start by checking for diagnostic error codes. The process is covered in the FAQ section. If the battery has been dead or disconnected you may need to run the car for a little while before any error conditions are logged again. Most codes require that the vehicle be driven under varying conditions and in some cases a number of occurrences must be noted before a code is logged by the ECU.
Just got my first supra noob questions help is appreciated vivalajon96 Non-Generation Specific Questions 0 03-29-2008 01:40 AM
Techincall questions.. im a supra NOOb Boostesi MKIII Supra 17 08-17-2007 03:53 AM
noob questions on 89 supra kidthunder650 MKIII Supra 4 03-03-2007 02:35 AM
noob questions peter88 Non-Generation Specific Questions 1 11-01-2006 01:36 PM
Noob questions CzA MKIII Supra 3 01-17-2006 01:18 PM
