I found a good deal locally on some Jaguar wheels with almost brand new tires. My question is, will the 108mm bolt pattern wheels fit my MK3? I want to say no, but if they do I want to snatch them before they're gone.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage. -1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car. -1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver. |
Fairly certain a Supra is 5x114.3mm, so the Jag wheels won't fit
You could get a decent machine shop to CNC you some adapters for just a few hundred though.... So all's not lost.
That would bring the total up to an amount which would get me other wheels I like more.
But for whoever has a 108mm 5 lug pattern it's a steal! I may get them just to resell :P
I was really just kidding. I didn't expect it would be a viable solution. Although if you know someone who's a member at a membership shop with machining tools they could probably cut a set for about $100. But yeah, I too prefer finding a set which simply fits right from the beginning.
wheel fitment question | StonecoreTx | MKIII Supra | 3 | 04-23-2010 12:44 PM |
can i use 5x112 bolt pattern rim | suprakillz | Non-Generation Specific Questions | 9 | 02-10-2010 02:12 AM |
Wheel bearing question | suprabahamut | MKIII Supra | 4 | 03-12-2009 01:17 AM |
Supra space saver wheel question | aquanuke | Non-Generation Specific Questions | 0 | 03-25-2008 10:24 PM |
What is the bolt pattern for... | nickalvrz | Non-Generation Specific Questions | 6 | 09-02-2006 05:56 PM |
