Old 09-30-2012, 09:34 PM   #1
dwthomas42
dwthomas42 is on a distinguished road
Default can i repair my plug wires???
ok i was changing my plugs in my 7mgte and when i pull out the plug wire the wire and the insulation pull out without the cap that goes on the plug can i repair this?? if so can someone tell me how they go back together??? thanks in advance
dwthomas42 is offline   Reply With Quote
Old 10-01-2012, 01:08 AM   #2
907mge
907mge's Avatar
For the price of a new set I wouldn't bother repairing a plug wire. How old are they?
Old 10-01-2012, 01:13 AM   #3
dwthomas42
Maybe a year but I went ahead and ordered some ngks to go with my new ngk plugs. It's just that its my dd and I didn't want to borrow a friends ride but I did so hopefully my idle issue will be fixed in a day or two. Thanks for the reply though.
Old 10-02-2012, 11:29 PM   #4
Well, this one I can answer from my phone. :P Yes, you can buy replacement contacts from most specialty auto parts stores (try the local race shops) and then you'll need a pair of crimps. You can use the existing boots and the crimps and the contacts should come with instructions. Thanks for keeping the problem simple.
Stripped plug! batmmannn MKIII Supra 8 05-18-2010 11:29 PM
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
plug wires revolution MKIII Supra 7 01-24-2006 07:28 PM
