-   -   Replaced HG, still overheating??? (http://www.toyota-supra.info/forums/mkiii-supra/20787-replaced-hg-still-overheating.html)
Wileyk24 10-02-2012 11:58 PM
Hey guys,
I just buttoned up my head gasket replacement for my 87 turbo. I used the toyota head gasket kit with everything from the head gasket up. I also did the timing belt/tensioner/and new water pump. I also ordered new seals for the turbo oil and water lines. In addition, I replaced the clutch fan, radiator, thermostat, and all coolant hoses etc with a silicone hose kit.
I started her up and she runs fine. Keeps good idle, maintains a normal operating temperature. I jump in and drive around the block and the temp guage shoots all the way up, we are talking less than a mile.
My lower radiator hose is very warm, which tells me my thermostat opened. The top hose is hot and has lots of pressure in it when I squeeze it.
What am I missing????
Wileyk24 10-03-2012 12:18 AM
FYI: Heater blows hot and no gurgling sound either...which I did have before I replaced the head gasket.
FRISBEE 10-03-2012 04:09 AM
may have a trapped air bubble, let it sit, cool off and top off the fluids. also check the fan clutch.
Wileyk24 10-04-2012 12:18 AM
Fan clutch is replaced, brand new unit. I will try to top it off and see if it bubbles at all. I am at a total loss here. Going to test my thermostat as well(which is new also).
Mishimoto 10-04-2012 02:21 PM
Hmm See what happens after removing air from the cooling system. Perhaps a wonky temperature sender is causing this?
Bill UK 10-04-2012 06:56 PM
Any increase in the level of the coolant expansion tank level when this happens ?
Wileyk24 10-06-2012 02:47 PM
Bill I will check. I am working on the car this weekend, I remember how much was in there before it overheated, so I will see if there was any overflow.
What are you thinking?
Wileyk24 10-07-2012 08:00 PM
Ok so no change in the radiator fluid level. The overflow bottle dipped slightly, less than an inch. The car is not overflowing coolant onto the ground either.
So today I decided to test the thermostat. I took it out, checked the bottom an it is a 195 degree tstat. I proceeded to boil it and with a thermometer found it wasn't opening until well after 200 degrees. Brand new unit, not functioning properly. So I went to autozone to get a new one and the system said I needed a 180 degree stat. So I bought it and took it home and boiled it. The new one open as it should and seemed to open easier than the last. Time to install.
I installed the new tstat, topped off all fluids and took her for a test drive. Good news, I made it a lot further than just one block. I actually drove all around town and on the highway. The car felt good, but my temperature gauge is settling at 3/4 the way up the temp gauge and staying there. Regardless of how I am driving.
So when the car is idling the temp gauge stays right in the middle. Once I start driving city or highway it goes up to 3/4 and stays there. Once it is up there it won't come down until I shut off the car, even at stop signs it stays up there. But once the car is off, I turn the key back on so the gauges are powered and the temp gauge sits at slightly under halfway which is perfect...
Anybody experience this before?
Wileyk24 10-10-2012 01:00 AM
Still at a loss here. Went ahead and ordered new oem thermostat and temperature sensor from Toyota. Even though I had brand new autozone stuff in there already. Apparently if I can buy a thermostat brand new and have it not work, its possible the temp guage is acting up too.
I will replace both and post back my results. Still very open to ideas....:dunno:
cre 10-10-2012 04:13 AM
Have you checked your ignition timing recently?
