Old 10-16-2012, 11:36 AM   #3
interested!
Exclamation 1992 supra
Taking apart the suspension is pretty straight forward. I would recommend soaking the nuts and bolts over night with penetrating fluid. My friend changed out all his bushing with polys. They need to be pressed in . Also polys are stiffer but the main problem is if you replace only a few you will be mixing new and old. It will most likely cause problems that way. I would recommend doing all of them if possible.
Hi! If the set-up is the same as my 1987 supra , the arms are fitted with adjustable camber bolts . I would advise taking photos of the settings of the bolts for rebuild . also , my bolts had seized completely and this job turned out to be a complete soab but attainable with a lot of patience and time , also the tracking will need to be checked afterwards .
Toyota Supra Turbo 1990 DrDeb Buy/Sell Cars 0 11-16-2010 11:09 PM
what do you think of this setup? Jareduhhhh MKIV Supra 4 02-19-2009 10:38 AM
Did they make an original single turbo supra (1994)? ts1994 MKIV Supra 3 07-20-2006 08:18 PM
Slow '90 supra turbo :( Bad turbo? DialTone MKIII Supra 6 06-09-2005 08:55 AM
