Old 10-17-2012, 05:16 AM   #1
1986.5SupraOwner
1986.5SupraOwner is on a distinguished road
Exclamation Need help with 86.5, 7M-GE. Won't start right away, has power, does turn over.
Hello !
So in the morning or even when I let my car sit for more then 4 hours , I go in and turn the key to start , it will try to start but no luck ... I have to do that about 3-4 times before it actually starts to gain rpms , then usually it will fail 1-2 times before it actually climbs to 2 thousand then falls to 1 thousand then back up to 2 thousand then down to 1 thousand and Im ready to go ....
Does anyone out there know what may be wrong so I can take it to a mechanic and get it fixed ??
Anything will be muchly appreciated
1986.5 Toyota Supra non turbo
7M-GE
1986.5SupraOwner is offline   Reply With Quote
Old 10-17-2012, 12:21 PM   #2
follow the instructions and check for error codes:
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=22
check your timing:
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=10
try cleaning your cold start injector:
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=50
use something sensor safe... possible fuel filter clog even??
check for codes, check timing advance, check cold start injector, report back with error codes.
Old 10-17-2012, 01:30 PM   #3
1986.5SupraOwner
Thanks alot ! Ill give that a try this weekend and see if it works
7M-GE
Old 10-18-2012, 11:02 AM   #4
ianstaley
ianstaley's Avatar
ianstaley is on a distinguished road
There are other possible faults here, I have had a similar problem in the past with my 7M NA, hard to start, hunting when idling but once running ok. While hot no problem restarting either but leave it a few hours problem returned. Turned out that the spark plug leeds were foobared. I replaced the leeds, distributor arm and cap. Solved the problem.
My local Mr.T shop told me it was a BHG.
Bored old git that loves his toyota's I have two one a Supra MK3 with a targa top the other is a brit Camry V6.
ianstaley is offline   Reply With Quote
Old 10-18-2012, 01:14 PM   #5
1986.5SupraOwner
thanks alot for that info! I will defiantly give that a try aswell
7M-GE
Need help with 86.5, 7M-GE. Won't start, has power, does turn over. 1986.5SupraOwner MKIII Supra 7 09-04-2012 05:45 AM
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
No power and Starter won't turn supraturbo_mk3 MKIII Supra 7 05-23-2011 03:57 AM
Hard to start / no power wsnipe Non-Generation Specific Questions 3 01-22-2007 08:18 AM
Won't start, but has power KNYFE MKIII Supra 3 03-30-2006 12:02 AM
